Lists of crap wrong with your cruiesr?
NorCalDoug said:
I managed to knock my front turn signal light out of its hole. I haven't tried too hard to get it back in, but it's not just a matter of pushing it in so it'll snap.
Sunroof leaks a tiny bit if I run it through one of those touchless carwashes with high water pressure. I don't do it too often, but it's nice to get the nasty goo off the rig after some of these trail rides at the carwash rather than on the driveway.
I have a faint brake light on ever since I adjusted the star screw on my e-brake.
The cover for the DS rear door speaker popped off and won't stay on anymore. I plan to replace the door speakers, so I havn't been too concerned about it.
My steering wheel isn't centered perfectly. It has a slightly off toward the left. I first noticed it after a particularly rough trail where I'd slammed the front end hard a couple times.
I broke a piece off my fan shroud a couple weekends ago; I haven't fixed it yet -- does that count too?
All pretty minor stuff.
what about the grab handle, eh, Mr. Prez...? :D
jklubens said:
Let's see:
Thermostat Broken
Which eventually lead to the replacement of the following:
Water pump
Radiator
passenger's heater core
main heater core
and various heater hoses
Valve Job
Valve Cover
Side Valve Cover
Rear Main Seal (Just completed) https://forum.ih8mud.com/showthread.php?t=50804
Oil Pan gasket x2
Tranny seals front input and rear output shafts (ATF in Transfer case)
No. 1 Breather pipe on tranny
Drive line clunk (Still a problem)
Smog pump check valve
Front Axle Seals
EGR Valve
Rebuilt Tranny
that's about it, for now.
that's it? booooriiiiiing! :D
Its a long list so here it goes;
leaking oil pan
three dash lights out
abs not working
clunking in driveline
clunking in front driver hub
tie rod hitting control arms (need to fix this soon)
has random dash lights come on and stay on
(check engine, oil, door open) :rolleyes:
two of the four fender flares hang off
and the worst thing of all, its smells inside like a rotten animal or something died in there...perhaps its the moldy carpet from being wet or the new 315/75/16 BFG MUD spare that is sitting in the back...rubber has a nasty smell inside a cruiser when it gets to be over 100 degrees outside.
Holy crap, now when I write this stuff down, my cruiser sounds like a total heep of s***!!! NA, its my cruiser and I love that damn thing!! :eek:
Can't believe I missed that one.
Add DS A-pillar grab handle.
Darned POS handle.
It would be fun to get the reaction of the discoweb guys when they see how few 80s have what they would deem as problems.
Cheers,
Sean
Oh yea,
New radiator,
washer diverter,
egr modulator.
My list is very short:
cruise control (with quick fix) will only work when it wants too!
missing running boards - sliders being done Sunday - Yahoo!
Muffler doesn't rattle against Kaymar bumper brace after Miller's!
stayalert said:
Wife and kids get to use it way more than me :crybaby:
Hey I've got that one too. But it keeps the mileage down.
Front Brakes and Rotors, Front End Rebuild. Parts in hand. Next week scheduled.
Passenger Side Door doesn't lock.
Burned out "D" light. In the past, a good whack on the dash would wake it up. Not now.
Maybe a few other things. (Yeah, right!)
The dirty sock smell is gone after a thorough A/C evaporator cleaning with DWD2. That stuff works!
-B-
(check engine, oil, door open) :rolleyes: ...
You might want to check your starter contacts - could cause a fire if that is the problem.
My list:
Rear axle rebuild (had the parts for over a year now)
Winshield washer diverter
Gas cap (and if that fails charcoal canister)
Slider vibration (I hope)
Washer bottle reloacation (This probably counts as a mod but I have the kit sitting in the garage)
Landtank drivers seat mod (yeah, been storing these parts too)
Tom
My List :
Skewed bumpstop. Makes a lot of squeeking when I drive rough roads where a lot of articulation happens. A real pain after a couple of hours.
Some thumping in the rear, only comes on rough roads. Probably the exhaust pipe, but everything there is properly fastened.
Low speed clicking somewhere near the front wheels. Sounds like lockers, but I don't have lockers.
Harsh gear changes. Still not yet bad enough to fix.
CDL does not engage. Thanks to Drexx, the indicator works again, but the CDL still does not engage. I'm still working it in the hope it will fix itself.
Leaky windsheild and sunroof but only during the heaviest monsoons or typhoons.
Leaking brake fluid well. That's what I get for using cheap substitutes.
Noisy door ashtrays. They rattle.
Kalawang
ABS Sensor
Rear main oil leak
Bent control arm
Hole in driver's seat leather getting bigger daily
CD player developing picky tastes in music
Groan from driveline due to caster issues that's going to get worse when I install spacers
Windshield washer reservoir/colostomy bag from the rear of an FJ60 (PO solution after supercharger) that leaks and has no pressure
"D" light is out - whacking on the dash does not work.
Empty secondary battery tray.
Unwired under-hood light (still looking for a ground switch.)
That's about all I could think of...
Brush scratches down RH side, paint scraped off bottom of sliders, gouge in transfercase skid plate, diff drain rings chewed up, rear sway bar scared, windshield cracked.
What a POS....:rolleyes:
My "D" light is out as well, not sure why maybe the lightbulb. To lazy to change it.
My list, today - since I had the cracked windshield replaced last week.
soon to be hole in drivers seat
Poor sound - especially the POS subwoofer
Centerlock sensor out - no light on the dash anymore, but 4L works fine.
need a 285 spare to go with the REVOs
more cold from the AC, it's hot in TEXAS this month
Jay
what's wrong with my '96?
230,000 miles,
hole worn in leather steering wheel at the very top center of the wheel,
all seats are dried, cracked, thinning,
check engine light on, (egr valve),
285/75's are starting to look a little worn out,
right rear cap on running board missing,
small scratches in paint on sides,
small dimples on hood and roof from a hail storm (PO),
gonna need brake work soon (first time in 40,000 miles that Im gonna have to do anything to the brakes),
AC compressor sounds like its gonna lose a bearing..... makes a whirring sound when AC on, but it's done that the entire time Ive had it, so I hope it will last at least another 40,000 miles,
oh - I almost forgot -
they didnt put the diff locks on my truck when they built it like they were supposed to.
a couple more things wrong, it does not have the 4.2 liter TD, or an auxiliary fuel tank, or an onboard welder or air compressor or how water shower or a winch or a hi-lift, or a slick little trailer setup with 6 bolt hubs sporting 16" LC alloys and 285/75 ta-ko's (and a couple extra mounted tires to use as spares for either the truck or the trailer)
give me a couple minutes and I might find some more things wrong with my LC
Hmmmm
1. Small rip in driver seat leather
2. Rear, exterior driver side vent cover loose at bottom
3. Check engine light on due to VSR et al
4. "Bling" gold color fading on exterior emblems
5. Won't play new DMB (Dave Matthews Band) CD but plays every other CD (400+) I own - I think??
6. Dead gnat in speedometer well - can't get it out.
7. A little "shimmy" at 70 mph - due for a tire rotation - may help.
Bbbbd, bdddbd, bdbdbd - that all folks! :grinpimp:
Funny thing I have as it's my only problem and it only happens when I have the kids with me. The radio seems to be way too loud.
