linerkit 4.2L
If I had to guess, considering the location. He is looking for diesel OEM liners. Many big trucks use serviceable cylinder liners for in frame rebuilds. I do not think the Toyota OEM diesels are that way though.
hello all.
the engine in my landcruiser lost alot compression.
engine type :1HD-T.
im looking for good quality engine rebuilt kit.
i dont want to use china junk
Not going to find that in USA, you will be better off asking in Australia...mine is a 1HD-T as well, but I can get everything just walkimg around...now...did you just loose compression or you are having a smoke curtain behind you? as it may just be cracked piston rings (happened to me...3 different cylinders)...for what is worth, a good overhaul kit here will cost you about $1000, then you will need to get valves and head gasket, as you need to say the number (I would suggest to use 5 always)
