Lifters
The Ghetto
Ok. I was talking to one of those good guys over at PepBoys about noisy lifters. I was thinking that I needed new ones. He said that lifters in older engines get out of adjustment all the time. Ok, I said. He said that when his were noisy he simply took off the valve covers, started the engine, and ratched down the adjustment until they quieted down. I would think that oil would be all over the place and i'd have quite a mess to clean up after something like that. Could this be done like this? Will I have to put down a drop cloth to catch all the oil falling out of the engine? Of course this is my first real engine to maintain so I didn't want to catch myself in a F#$% up. Any guidance would be appreciated.:cool:
Hydraulic lifters need to have the proper preload. You might want to check a manual for that engine to see what is the proper method to adjust the hydraulic lifters. Yes, it does tend to get messy running the engine with the valve covers off.
Ahh, I don't think you want to "ratched down the adjustment until they quiet down." You can damage the valve trainand burn valves. There is suppose to be clearance between pushrod and rocker and it may be different between intake and exhaust. Like BSevans mentioned, there are specs for the engine. Do you know you have hydraulic lifters? If you have a solid lifter cam and lifters, they do make more noise than hydraulic lifters.
Start with a valve adjustment. Get the specs and you might even pick up a special tool that several companies make that makes the whole process easier to do.
GL
Ed
Ok. Well, I just developed a very distinct lifter sound coming from the engine closer to the firewall. It sounds like a old school train when I accelerate. It sounds bad like i'm a frickin choo choo train.
Hmmmm, sounds like it sounds like an exhaust leak....if we rode the same bus;)
Ed
I thought about that but while it idles it doesn't do it. I haven't gotten in there to take a good look or listen well enough. It's possible because right around where the noise is the headers marry up with the exhaust pipe. Who knows?
x3 on the exhaust leak, put your hand down near the exhaust manifold and rev the engine at the carb linkage, you should be able to feel it. I have had exhaust leaks that don't really show themselves without throttle because there is not enough exhaust pressure at idle to make them noisy...
Noah
Get a few feet of hose, heater hose works well, and listen at one end while you put the other end on the valve cover and all around the exhust manifolds/ doughnut gasket areas. The sound will be pretty loud when you put it at the sorce.
