Lift?
Fargo
Need some help determining if or how much lift I have. Anyway, I can tell by measurements? The pics have 235/75/15 on it. Hoping to put 33 or 31 on her.
Sometimes you can clean off the top of the spring and find the part numbers.
looks like the 2nd and 3rd leaf have been changed out, they appear thicker and not tapered on the ends.
do the fronts have the same setup? it looks to be higher in the rear but with no hardtop on it, that could be throwing things off.
how does it ride? I'm thinking rough with the vertical shackles.
Oh yeah...it is a rough ride, but I have only owned her for 6 months and really have nothing to compare it to.
The backend actually sags a bit. The picture is a little deceiving. Here are some better ones.
Maybe my money would be better spent on new lift kit.
Looks like no lift at all. The 235/75R15 is equivalent to ~29"x9.25x15." You should have no problem at all with 31"x10.5"x15" on those springs. If you want to go to 33" tires you will really need to get a 2.5" lift minimum.
If you want to keep the springs you have, I would tear out the old rusty shackle pins and deteriorated bushings and install new pins and bushings. I would also recommend some Bilstein shocks. It will be hard work, but will give you the best ride you can get with the springs you have.
Previous owner installed "Add-a-leaf" springs into your stock spring pack, now rides stiff for two reasons: (1) Stiffer spring rate than stock, poo poo. (2) Added leaf created more spring arch, which placed spring shackles vertical, which gives stiffer ride, poo poo.
This Forty has a surprise everywhere I look. So, it does look like I have an Add-a-leaf in the middle of the springs on the back-end...or aleast it is different than the others (thick and not tapered). So, now I am looking for advice on this. Would this be the time to replace the springs? If so, I am leaning towards a 2.5" lift so I can fit 33s. It is not an off-roader..just used to drive around for the most part. Any direction that I should look towards. Thanks
