We can wait for Slee to confirm, but why would Slee arms and a stock shaft work with 6"? There is alot more caster correction in those arms than in caster plates, no? Which means you've spun the pinion angle even more, the extra length of the arms should relax the driveshaft angle a bit, but I can't believe it'd be enough to keep the stock shaft. Since he includes it in his kit, this would also hint to it being necessary.
What about 4" with Slee arms? Couple people running that combo with no issue.
Whatever drop bracket matches up to caster plates as far as deg. correction, 'SHOULD', work out the same vibration wise. Sorta like if you had caster plates that only adjusted the amount of blue bushings, it 'SHOULD' have exactly the same vibration issues or non-issues.
I'm one of the first data points for J"s and 3" front drops for sure, and that's just one data point that works, as we know, some people get luckier than others.
The stock drive shaft has 2 alignment situations that work. The criteria is that the angles be the same with an amount of tolerance. So the two situations look like this \--------/ or /--------/. So I thought that the arms actually rotated the axle past the alignment for a DC shaft which is this |---------/ to this /--------/ which would work for a stock shaft.
The list I posted was based on getting both caster within spec and having a vib free truck. If Slee has a vib free setup with his arms and you put it on a lower lift you will have a vib free truck but the caster will likely be outside the factory spec and over 4*.
Privately I did mention to WoodyFJ80 that swapping out the 3" drop brackets for the 4" ones and installing a DC shaft should correct his problems. And quite honestly I would expect MAF to work with him on that swap and not make him eat the whole cost.
Right now his front u-joint angle is 2* which is outside what a DC shaft needs and the difference between the front and rear u-joint angle is outside what a stock shaft needs. Some trucks have a greater tolerance for how far these angles can be out and still run smooth, his isn't one of them.
If he is indeed at 5" of lift I'm guessing that his caster is around -0.5*~-1.0* with the drop brackets in place.
I have nothing against the drop brackets as far as correcting caster. But there is very little data out there about them from what I have read and wasn't confident adding them to the list.
To be honest I have over 10 trucks running my plates without issues that I'm aware of and I still respond to vib questions as there is no guarantees.
From working through a lot of lifts with people I've come to the conclusion that it's best to pick a caster solution for what height you want and then build to that height. Another words, if you want a 3" lift, install the appropriate correction for 3" and then select the springs to provide that amount of lift base on your truck's weight. It's a lot easier to adjust height to get the caster in range than it is to do it the other way around.
I know this is backasswards of how people think about this stuff but if you think about it, it's the easiest way to end up with a smooth running truck that handles properly.
It will be interesting to see his caster specs.
