lift drop brackets
I have the J's and the caster plates, but opted for the so-called stink bug look. Started out with spacers on the front and had crazy vibrations. Took those out and am now down to chasing rumbling u-joints. DC driveshaft would probably take care of my rumbling, but can't justify the $$ for right now.
Guys, far be it for me to be the voice of reason (it's never happened before) - but debating the advantages and disadvantages of drop brackets vs. other caster correction options has been done to death, and redoing it isn't helping his issue. Go start a new thread on it if you like.
1st. How do you know you got 5" of lift?
2nd If you know that cause it's 5" higher than before, you may have been low (sagg'n) before hand. Measure wheel center to wheel well, and I'll measure mine for comparison.
3rd You don't need more caster. If you have vibrations, adding more caster is just going to make it worse.
4th Start with the simple stuff first. Grease your U-joints. Does that have any effect? Even a little? I wouldn't necesarily jump to a DC shaft. You may just have worn out U-joints. Or worn IN unjoints. After they opperate at the same angle for a couple hundred thousand miles, they sorta take a set. You start operating them at a different angle, though it is fully within the design specs of the ujoints, it's out of the range where all the wear was. Since the newest 80 series is 10 years old, it's not at all unlikely that the joints are just worn enough that you wouldn't notice it on stock height, but would with a lift and caster correction - of any type (won't go into it here, but if you search, you'll find the caster is the same, and therefore the pinion angle that is causing your vibrations).
5th Try taking your trim packers out. That will releave some of the pinion angle. You may not want it to sit that way perminately, but it at least might get rid of your vibes till you can work out new u joints or a DC shaft.
6th let us know what solves it, so we can add the data point.
WalkingEagle,
1st. I measured from the wheel center to the fender well and got 25".
2nd. U-joint just replaced within a month. All done correctly.
3rd. The vibs where before the trim packers. Noticed no difference in vib before and after.
4th. I will take the front ds out to see, and then go from there.
5th. If it is the problem, goin to Woody's drivline shop here in town and see what he can do for me on mod the OEM DS or on a DC shaft.
Finally, I am just trying to once again narrow it down, so I just don't buy this and that and hope it works, I need to know before buying it.
I recently found that my MAF 3" lift kit has actually given me a 5" lift.
Woody, I know you are frustrated, but before you throw more money at this step away and analyze what is going on. Why you got 5" of lift with a advertised 3" of lift is probably the use of springs that are rated for additional weight on a truck that has none. This is a very common problem.
So first of all, you need to determine if you need or want the extra lift. If you do, then you have to deal with the issues you created. If you do not want to deal with it, then lower the truck down to a reasonable height where you do not have these issues. Few people actually consider this route, and I do not know why not.
I the drop brackets I have with the kit is a 3".
The brackets is a technically good solution for fixing the caster if you have 3" of actual lift. If you have more, they are not a fix. The problem is that they only address caster and has nothing to do with driveline angles and your possible source of vibrations (neither does any other caster solution).
First you need to understand what caster is. I am not going to go into that, just state that if you rotate the axle, the pinion flange angle changes and the net result is your u-joints are at different angles. Pinion angle and caster are coupled physically by the axle housing. The third member housing and knuckles are set by the factory at a specific relation to each other. The only way to decouple them is to cut the knuckle balls loose and turn them, thus changing the relation between the third member housing and the knuckles. This is referred to as a cut and turn and a common way to address caster and driveline angles on vehicles. The 80 has some specific reasons why this does not always work due to interference. Search "cut and turn" on this forum and you will get info.
So in short, lifting the truck rotates the axle, so caster and driveline angles change. There are various ways to correct caster (ie, rotate axle back) but when doing so, the driveline angles are not the same anymore since the axle is now further away from transfer case.
There is a ton of information on this in the FAQ.
Due to the 80 setup, there is a sweet spot that you can get a double cardan shaft to work and have correct or reasonable caster. This is what you are shooting for.
You should also be aware that a double cardan shaft is not a magic cure all for any situation. Lots of people think it is, but in reality the spot where the double cardan work is actually more limited than a regular shaft.
Does anyone have any experience with a 5" drop bracket and did u use the CC bushings? Or, should I get rid of the brackets and use a CC plate to get totally rid of the vib I am receiving? What is the best solution for resolving the vib coming from bad caster? PLEASE Any Input!
I know the above is not a solution for you, but in short there is no magic answer that we can just give you. You can probably search threads on Schotts and LX450 and find enough info to totally confuse you.
WalkingEagle,
wow - my J's are
front: 23"
Rear: 23.75"
Slee was guessing that's 4.5-5" lift in the rear - based on other trucks (had to search some for that)
Untill this weekend, I was running NO bumper up front to bring it down.
How long have you been running them? Just curious if they've had enough time to 'settle' yet.
I got away with no vibes, so I consider myself lucky.
As I see it you have two basic options here for a best result solution.
1. pull the front spacer, remove the drop brackets, swap the rear springs for a non J springs and press in Slee blue bushings and run a stock shaft.
2. remove the drop brackets, install some caster plates and run a DC Shaft.
Both solutions will probably be light on caster but the vibs should be gone.
These two options are based on working through a bunch of installs here on the forum. Now this doesn't mean there isn't a solution that still allows the use of the drop brackets, I just don't know of one.
If you insist on keeping the drop brackets and your current springs and spacer you're pretty much on your own and more threads asking for advice really isn't going to bare any fruit.
He could also leave in the drop brackets and install the caster correction bushings of his choice. Problem is, he doesn't even know what his caster is, he may not need to do anything. Then after he knows the caster is right and won't need to be adjusted any further, he can find a solution for his vibration, which still may or may not be from the driveshaft.
-Spike
-Spike
Exactly, HE needs to do the leg work and work out the issues. More posts here on the forum isn't going to shed any more light on his situation because there just isn't much experience on here with his component choices.
One would hope the manufacturer would step up and help resolve this but that doesn't seem to be the case.
I only mentioned the two solutions above as cost is a concern and working this out and using the pieces he has could get costly before long.
But, Like Slee and I said (didn't think I'd ever start a sentance that way jk) - it doesn't matter what caster correction option he has chosen, the problem is the driveline angle which is going to be the same unless he runs less caster, or less lift. Slee blue bushings, like you said would be light on caster. Caster plates, unless they are the adjustable ones, are only good for setting "X" amount of caster, so they're limited on which lift heights they'll work on. Since I believe (and I'm sure I'll be corrected if I'm wrong) caster plates were origonally designed to work with J's with spacers, just like he's running weren't they? So if he's too light to get the front end down low enough for 3" drop brackets, he's not going to get low enough for caster plates either.
Go get the caster measured. If you're really at 5" it probably is already on the light side, and doing anything that adds more caster than you have is going to make the vibes worse.
Throw some big bumpers on and get that lift height down :)
Since you said you had trouble with the packers in, getting rid of them won't solve the problem, you have to go lower than that apparently. So get some OME 2.5's, or some FOR 3.5" and get the lift height down a bit lower.
Or - if you like the height - and unlike Slee I do understand why people don't think lower lift height is an option to solve vibes - it's cause people want tall trucks :flipoff: - if you want to keep the height you have, go custom DC or CV driveshaft.
:flipoff: didn't work :D
I normally suggest lowering the truck for people that are against spending any more money to fix the truck.
The problem is that one does not know how the suspension was sold to him, or how he bought it. Was it sold as a solution? Was the application discussed? Was spring rates talked about vs load on the truck?
As everyone suggest, get the caster measured and see where you are at.
read what you just wrote, the problem is the caster option he chose. That option doesn't align for a DC shaft and apparently puts the drive angles in the fringe area where the stock shaft will run properly. I say fringe area because you don't have any issues.
So basically he needs to go with less caster correction and the stock shaft or more correction and the DC Shaft. Once he decides which way to go he can then adjust the height to match the correction chosen.
What will the caster measurement to tell anyone? His solution to the vibration issue still remains the same even if his caster is ideal.
Choose a vibration solution and then get a caster reading and either add, subtract or leave the height alone depending on the outcome.
It will tell us how far he is out or not. If he is in spec, then he either does not have 5" of lift, or he has one of the rare trucks with plenty of caster from the factory.
It might also give us an idea as to how much to drop it down if he is so inclined.
I am not sure how he is going to get a "vibration solution" at the lift he is at.
I would have thought it would be obvious. If he fixes the vibration but has a caster problem, he could end up with another vibration problem when he fixes the caster later. He hasn't addressed his caster, so that's first. Once the suspension is in spec, he can look at fixing other things, like vibrations. It's pointless to fix the vibrations if there's a chance he'll have to change the angles again later.
-Spike
you guys are way over thinking this. There are basically 5 setups that don't have vibration issues.
1. stock height - OEM and stock shaft
2. 1.5 ~ 2.0" lift - OME and stock shaft
3. 2.0 ~ 2.5" lift - Slee blue bushings and stock shaft
4. 3.5 ~ 4" lift - caster plates and a DC shaft.
5. 6" lift - Slee arms and a stock shaft. (Slee confirm)
Now there are some exceptions but those are pretty good guide lines and those who have actually bothered to take all the readings have fallen into those brackets.
From another thread he measured a 2* angle at the front u-joint. So he needs more correction of that amount to align for a DC shaft.
If the drop bracket is a true 3" then that is responsible for 5.22*. So add the 5.22* + 2* means he needs a total caster correction from stock of 7.22* for ideal DC shaft alignment.
there are only two types of shafts available so he basically needs to pick one and apply the appropriate caster solution and then adjust his height to meat his caster numbers.
There are some heights that just won't work and depending on your trucks beginning caster it will vary. You can't arbitrarily pick a height and have the caster within factory specs and a smooth running drive line all the time. You need to work this stuff out ahead of time.
You don't even know it's a driveshaft issue to begin with. He could have a guinea pig on an exercise wheel under his seat for all we know. You're jumping ahead on picking a solution in my opinion.
I know that Slee packaged a DC driveshaft in my 6" lift kit, so I'd question #5.
You are obviously hung up on the brackets. There's no reason they won't work if he can get the caster within spec. They might even help by keeping the angle of the radius arms closer to level, which will make it ride smoother over bumps. I'm not a fan of the drop brackets, but I can concede they might have some advantages to go with the disadvantages.
Just because you know of 5 ways to set up a truck doesn't mean there aren't six.
-Spike
-Spike
maybe I am jumping ahead but I've had several exchanges off line and I think he has a drive line vibration.
As far as 5 is concerned, I posted for Slee to comment as I didn't know for sure.
If there is a sixth one post it up as it will help everyone.
By all means Spike work with the guy and solve his problems. I had him take some measurements and in my mind the angles aren't conducive to a smooth running setup.
