lift drop brackets
Ogden, Utah
I recently found that my MAF 3" lift kit has actually given me a 5" lift. I the drop brackets I have with the kit is a 3". Does anyone have any experience with a 5" drop bracket and did u use the CC bushings? Or, should I get rid of the brackets and use a CC plate to get totally rid of the vib I am receiving? What is the best solution for resolving the vib coming from bad caster? PLEASE Any Input!
The drop brackets don't give any lift at all. The lift is from the springs. I have 3" drop brackets and J's, and it works wonderfully, no complaints.
There are many causes for vibrations in lifted trucks. Do you have information that leads you to believe yours are coming form bad caster? Could they be drive shaft related? Your sig states OME J's and a spacer- is that the kit from MAF, or is this something you put together?
To fix your caster, you need to know if it's a problem. I'd get a measurement, and also look through some past threads on vibrations. Search for 'Shotts', he's been involved in several. Do some of the testing, like removing driveshafts, having tires balanced, etc.
-Spike
I have just the fronts, there alright, solves the problem till a better option comes around..............
Thanks alot! Everything on the kit is from MAF, and I did call them with no help. I also posted some past threads about the vib. I got alot of feedback and helpful info. I did measure the drivline angle and it was about a 2*. So, who can answer my question about CC bushings, larger brackets, and or CC plates from Slee? Which would be the best option for a smooth ride again?!
if you don't believe a better option existed before those were ever made you're already too far gone.
Caster bushings are AT LEAST as good, if not better due to clearance under the truck, for under $100...
Caster plates are even better, still under $150...
Any number of custom arms from Slee, Snake, etc are MUCH BETTER options for under $1000...
...but if you want to install 4" lift springs and then 4" drop brackets so you can fit a 35" tire, and you're main concern is wheeling the streets of SoCal, please disregard the above options.
'Everything on the kit is from MAF.' Is it sold as a kit, or did you mix and match pieces? What is your caster measurement? No one can tell you if you need additional caster until you know what your caster is now. Also, your driveline angle measurement- is that at one end or both ends?
And again, how do you know it's a caster issue causing your vibes?
-Spike
Everything was in a 3" suspension lift kit from MAF, the trim spacers is what they offer for "level stance".What or how does one measure the caster? What shop? I measured as Landtank had told me to. It is just the front U-joint angle. What other possible areas would cause the vib after lift install?
Golden Spike, Behind the Rocks, Hells Revenge, Steelbender, Cliffhanger, all of Big Bear, TDS and one rock strike, I only run the fronts, and putting on the brackets VS the castor parts was a compromise. I know what your opinion is, I read it here in about 5 threads. But I have them, their paid for, they work and till I get a suspension I like or settle that maybe I need a crawler(MY 55 buggy) they are gonna stay. :cheers:
FWIW, Im the guy that took your rims to Robbie in Moab a few years ago:flipoff2:
and I've seen a stock FJ Cruiser do all of that so what's your point? You explicitly stated that you thought it solved the problem until a better option comes around. I was just asking, since it seems ridiculous, how you could overlook the pre-existing options that were out for years prior to MAF drop brackets, used on thousands of trucks with apparently pretty decent results. Don't the OME caster correction bushings correct the steering back to, or close to, factory specs? Don't the caster plates do that too? And don't they keep the break over angle of the truck from decreasing like the drop brackets do?
You bought the brackets as an added expense to whatever suspension you're running and there are just cheaper options out there to deal with it at that level of lift. It's your money you spent and if you're happy then more power to you. Just don't tell me how freaking great they are and they never hit anything. You know I'm in Riverside so let's play follow the leader.
And thanks again for taking the wheels to Robbie :cheers: I will buy the beers after you smash those brackets bits...
An alignment shop can measure your caster, camber and toe-in for you. Then you will know if you need additional caster, and how much, which will help determine what type of caster correction will work for you. An alignment can also fix or point out other problems you may have. However, there's more to the story. If you need additional caster, adding it can possibly make your vibrations worse. The pinion angle is usually the culprit that causes driveline vibrations for an otherwise healthy driveshaft. The pinion angle changes when you change the caster of the front axle, and when you lift an 80 and correct the caster it usually puts the pinion angle in a bad place. How bad depends on how high you lift it, and the fix is usually a DC driveshaft.
But wait! There's more! You may not have any issue with your pinion angle. You could have a bad u-joint or two, a tire or driveshaft out of balance, some mud in a wheel, a separated tire belt, or something else. Checking and fixing your caster is a good place to start, but it's just one of several troubleshooting tactics you will probably need to employ. A tire rotation and inspection can sometimes highlight a tire problem, removing the front driveshaft can eliminate u-joints or driveshaft imbalance as an issue. Did you change your u-joints recently? I always preach changing them- front and rear- on older vehicles when installing a lift. The new angles that they have to operate at sometimes make them show their age.
So, there's no simple answer with the information you've given so far.
-Spike
Back to the thread, what options do I have? Should I remove the brackets and use a CC bushings. or plates? Or leave them and add plates or CC bushing? Or, Just say #$^& it and buy a DC shaft when I can? Where is the place or shop to get your caster measured? Alignment shop? I am not sure. I jsut want to narrow it down so I can spend the $ wisely, rather than do this and that and hope it works. ITS JUST A PITA!!! Why is it some LC are differ than others when lifted. Some have the vib issue and others with the same lift have no issues. Buy a 3" lift and get a 5" lift out of it. "What the Hell?!" Thanks John
THANKS SPIKE, I just noticed your post after I posted the last one. And, Yes I just recently replaced u-joints with the proper mechs. I have elemintated all tht you ahve mentioned but, I will get it aligned and see where she sits. I am really convinced that a DC shaft is the way togo, or what I have to do. Just when I can afford it. New tyres and an ARB front is maybe the first todo on the list. Then the rest. I just don't know anymore. It is fustrating. Everything is so damn much $ anymore. I need a second on the home, just to get things on the LC working order. Thanks John
I will when I see a viable 3-4 link kit on the market, or I take pics of yours and have a shop do up a kit for mine, I'm really waiting to see Carl's kit but It sure has been hush hush. you sure get wound up about those things:flipoff2:
I think you need to call them, I did the purchase that made them change the kits, I told them, 4" with only the front brackets, lines and misc brackets, they sent me J's with 1" spacers, no vibe issues, not sure where your getting the extra 1" unless they sent the comp springs?
If your problem is front pinion angle, remove the front driveshaft and it should go away. Then you'll know you need a DC driveshaft. I'd find out how your caster looks first though. As far as tires and ARB before the DC driveshaft- keep in mind that the vibe probably isn't good for your pinion and t-case bearings. If it drives smooth without the front driveshaft, I'd leave it out until you can fix it.
-Spike
