- Joined
- Nov 14, 2013
- Threads
- 69
- Messages
- 583
- Location
- Huntsville, AL
- Website
- www.rocketcitycruisers.com
Welp guys and gals, back again asking the collective an opinion. 1996 LX450 with 244 on the odo is what i am working with today. I did the front knuckle rebuild about 3 weeks ago and all of that seems to be ok ( at least nothing is leaking and the damn thing still drives so that spells success to me). I did notice, however, before i did the axle rebuild i was getting a low pitched hum noise that sounds like it is the rear diff. When i did the knuckles, i also did an ome 2" spring lift on it and put 285 BFG KO2's on it just for good measure. It sitting in my garage for weeks on end as i tackled a few little things at a time, i dont remeber how bad the noise was at first but now that i am in it every day i wanted to get some advice.
The best i can describe is it sounds like you are driving over the lane drift warnings on the interstate (the idiot bumps on the shoulder of the road) just with no vibration. i hear it most prominently from 28-33ish MPH then it quiets down but it never goes away. Seems like it is slightly more noticeable on rougher roads but that could also be a combination of the lift and tires. i noticed there is a little rattle sound metal on metal, when i let off the gas and just coast but that could be entirely unrelated.
I pulled the rear driveshaft and checked the U-joints. At some point they were changed because they have zerdts on them and from what i understand the factory ones didn't. They felt nice and loose but didnt have any play in them, i greased it and stuck it back in.
Maybe a dumb question, but a 2.5-2.75" lift (overall) wouldn't have changed the driveshaft angle enough to cause problems would it? I am figuring it is probably an issue with the pinion bearing or the 3rd in general. I have just been fearing it might be something with the tcase because i cant manage to get the CDL engaged in 4 low. Once again, throwing lots of things out there that are probably unrelated. I just got the truck about 4 months ago so i am still trying to figure out the quirks. I dont understand it nearly as well as my old fj62
