Now, diving back into the EWD, let's figure out which circuits are downstream of J4 and which other junctions or connectors are downstream that we can pull apart to figure out which circuit is causing the short. Here's a list of the circuits that are fed by the GAUGE circuit and J4:
AC Pressure SW [J4 -> EA1]
AC Amplifier [J4 -> EA1 -> IG2]
AC System Amplifier [J4 -> J7]
Air Inlet Control Servo Motor [J4 -> J7]
Air Vent Mode Control Servo Motor [J4 -> J7]
Center Diff Lock Control Motor [J4 -> IH1 -> EC1 and J4 -> IH2 -> EC1]
Center Diff Lock Control Relay [J4 -> IF1 -> J2 and J4 -> IH1 -> EC1]
Combo Meter [J4 -> dash gauges]
Cooling Fan Radio and Player [J4 -> J7]
Electronically Controlled Transmission Pattern Select Switch [J4 -> IH1 -> EC1 and J4 -> IH1 -> IH2]
Heater Control Switch and AC Switch [J4 -> switches]
Rear Heater Switch [J4 -> switch -> J7]
Rear Window Defogger Switch [J4 -> IF1 -> J8]
Back-up Light LH/RH [J4 -> IH1 -> BQ1]
These fall into a couple of groups.
The first group is the circuits that go to switches and/or gauges:
These can be eliminated quickly by making sure J4 is reassembled but then unplug the gauges/switches and see if any fix the short circuit.
The second group is the J7 group:
The Rear Heater Switch also uses J7 but we already eliminated it in the switch group.
The third group is the IH1 group:
The last group is the EA1 group:
How am I going to test the last three group assuming it isn't caused by one of the switches? In the EWD each circuit has a pin number associated with it as it passes through J7, IH1, and EA1. I first plan to reassemble J4 and then disconnect J7 to see if the short goes away. Then reassemble J7 and disconnect IH1, and then repeat for EA1. This will narrow it down to the group of circuits. At that point I can test the downstream pins in the offending connector to figure out which circuit is shorted.
I'll probably get all of this done tomorrow and report back with pictures. Right now my truck is in sad shape:
Uff da.
