The map lights aren't that bright, but then again they really aren't designed to be blinding since they point at your face.
Which are brighter, the ones im zee vorvagon or yours?
Alright ladies and gents, as Paul mentioned, I recieved my kit in the mail yesterday but couldn't get to it until this evening due to work.
I have all of the bulbs installed, and I must say that for the money, I am impressed with the output. A few things worth noting:
1. I started at the front of the truck working my way back. When I got to the second row of lights, as I was installing third festoon bulb I heard a mild "pop". Then, no lights. The 10A fuse blew out. Threw in another 10A, blew instantly. I had no more 10A fuses, so I threw in a 15A - pop. Finally out of desparation (and out of a lack of any more small fuses that would fit), I threw in a 30A fuse and I also ditched that particular bulb thinking that it may have somehow been built incorrectly. I installed the spare festoon that Paul included, and that combined with the 30A fuse solved the issue. I intend to drop down to a 20A fuse to see if it works, as tripling the amount of max current through the wiring doesn't seem like a good idea to me.
I had this happen also but it was because I was using a screwdriver and sweaty hands trying to get the old festoon bulb out and install the new LED one. Once I slowed down and made sure I was not shorting anything, it went issue-free. What light was it? On mine it was with the 2nd row personal (outside).
2. I am noticing some color temperature variences among the bulbs. Some are more blue, some are more purple. No big deal for the money.
There is a difference between the 48s and all other bulbs. This is clearly shown on post #1
3. While they didn't seem very bright to me at dusk when I installed them, after dark it becomes quite clear that they do in fact put out a substantial amount of light - especially the larger 48-LED festoon bulbs. They flood most areas of the interior. The map lights aren't that bright, but then again they really aren't designed to be blinding since they point at your face.
Do you mean the red map lights or the 10 LED map lights?
4. On one of the door bulbs, I couldn't get the light to come on when pushed all the way in. It would flicker as it went in, but then went out when fully seated. To remedy this, I simply bent the contact wires on the base of the bulb out a little bit which solved the issue. I think that this problem was more a function of a loose door socket rather than a bulb issue.
I expect this to be a common issue. You just have to bend the wires out a little.
5. Paul's packaging was impeccable - sets of bulbs were wrapped with enough padding to remain separate during shipping. The foam was secured with a rubber band and taped to ensure nothing got jostled around. Top notch job there, Paul.
Thanks!
All in all, I am confident that it was money well spent. I am a little bit worried about the fuses blowing, but the issue seems to be taken care of for now. I'd say send him your money and go to town - the extra light is quite nice.
Thanks for this, Paul. Great job.![]()
Glad you got them in and working. Ill address your points in-line...
Once we get all of this cleared up I will start PM'ing people on the list and accepting payments.
If you happen to have a kit left over, please let me know. Otherwise how can I get on the next list.
Added you. I had an issue with the second shipment as it appears to have been sent back to China (from NYC Customs) but I have been informed that there is a whole crew of 11 year old boys working 17 hour shifts trying to figure out what went wrong.
11 year olds? Wow, they must have gotten management involved.![]()
Senior Management at that...So did you get a 10 amp fuse back in its rightful place? I am holding up on shipping till I hear that the issue has been resolved.
That is friggin hilarious right there! Can you add me for a second set, as well?
Thanks again!
Yep, you know the rules.![]()
