It looks like I live about 30 minutes of you in Alvin. I don't mind helping out on a weekend when I'm not working. I'll PM you my number and we can get together and I'll help you out the best that I can.
I just wanted to add that I do all my own mechanic work (shade tree) and I have welding and cutting equipment at the house. I don't mind helping a fellow mudder out.
This is the sh!t! Drive up. Bring some Lone Star or Tito's and start wrenching. If y'all don't drink bring some Whataburger or Dickey's.
MUD is the best fraternity there is. I've been helped or helped people hundreds of times. I could go in to my story of the local Indianapolis chapter helping me while I was going through cancer but I won't. Needless to say, they stepped up and helped me out more than you can imagine. For that I will forever be grateful and willing to help others out. If I still lived in that godforsaken state of Texas I'd offer to help you out as well.
By the way, 1992 is the best year of the 80 series. The motor you have is slow as sh!t but it is bombproof. And incredibly easy to work on.
See also: My signature.
See also: Search for
@jonheld He is the resident 3FE (your motor) guru. He literally knows everything about this motor (and a ton of other stuff). He's incredibly helpful and methodical. If you have questions, ask. THEN LISTEN AND FOLLOW HIS DIRECTIONS! I've never seen him stumped.
Here's a start for you:
http://www.sdsysdesign.com/tlc/images/Strife/3FE TuneUp.pdf
This is all stuff you can do with basic tools and getting your hands dirty.
As for your birfs clicking, it isn't the end of the world, yet. Make sure there is grease (moly blend valvoline from auto zone is fine) in the knuckles. The knuckles are the round balls on the end of your axles behind your wheels. Look on the top of the ball, there is a SQUARE PLUG. Take a 13mm open ended wrench and open that up. Take a zip tie and stick it down in. Shine a light down in and see if you have grease in there. Add grease until it is about 3/4 full. To add the grease you can use a grease gun and pump it a bunch of times or use the "ziploc method". Search for that and you'll find it. You basically fill a ziploc bag with grease, cut a small hole in one corner, and squeeze it in to the knuckle. The clicking is annoying but not catastrophic. They aren't going to explode. Then on your front axle there is a round differential (aka diff) with two plugs. One is for draining, one is for filling/observation. Open the top one. Stick your finger in. The gear oil should be to the point where it will overflow out of that opening. I would open the bottom one and drain it out and fill with new gear oil. Check for shavings/metal. It will smell really good. You might want to dab a little behind each ear. It is know to attract the ladies.
Now go do all of this stuff and report back to us. And post some pictures for crying out loud!
Welcome!
