Agreed. I’m in for at least that much and I’m doing it myself.take the new amp and speakers and wire job for 1100 and call it a day.
Does the GX 470 have complete driver dual zone climate control with factory equipment or was it like the LX/LC that has a separate rear AC control behind the 2nd row?I just installed this in my GX 470 and dual is working.
I have a 2003 Land Cruiser. The green harness fixed the CC issue for me. It seems newer models were plug and play.
I would try to get the green harness from the vendor that you bought the radio from.
Yes.Can this be set to the imperial system for temp?
Anyone installed a new backup camera yet and ran the new rca and power cables? Running into issues with routing the cable through the upper tailgate. Thinking of installing in the lower tailgate as cable routes work a little easier back into the cab.
I tested out the power cables signals with a few different cameras to the new radios I’m looking for the optimum route for the new wiring.
Also thinking about getting a swing out tire carrier and I’m not sure if I should just wait until I get that done before mounting the camera. Suggestions?
Sounds interesting. Can you post some pictures?Late response here, but I did this. Mounting the camera on the inside of the car. On the top center of the rear window - there's a piece of moulding that runs across the whole back. Drilled right in the middle and ran wires down and to the head unit. It isn't messed up by snow/dirt and have full viewing access to whats outside - even above my bike rack.
Recommend for easy installation and weather resistance. Also, no holes in the body itself.
GPS: they come with their own receiver that you mount somewhere. I have mine mounted at the top edge of the windshield.Thanks for putting this thread together with so much great info. I keep thinking of getting one of these for my 04 LX and the more I read the more I like what I am seeing.
I do have a few questions though.
Does this utilize the factory GPS for a signal? Or do you have to have a wifi hot spot to get maps / any GPS?
For those of you with the TPMS options how are well is it working and what sensor type are you using?
Also for apple car paly / andriod auto, I see that it has two options for wired or wireless. Can the wireless option not have a wired connection as a backup? Or for charging the device while being hooked up? I do not know much about the car play as I have never had it so any information will be great on how it works.
Does the 6 disc cd changer still work or there a way to convert it to a DVD player?
Thanks for any info and keep up all the great work you guys are doing in helping troubleshoot these.
Yep, and the Bluetooth quality is pretty good.I don't care about Android Auto so much but can I Bluetooth stream audio to this unit?
