If the rig has had good maintenance and has low miles, you can get away with a front end service which will cost you about $350 if you do it yourself and another $500 if you get a competent/fair mechanic. If the thing hasn't seen a front end service and hasn't been lubed you might have a birf and/or axle replace. Birfs are ~$600 and the long/short axle average is $125-ish. So that could get you up to $2000 but you should NEVER have to do that again if you take care of it and you probably don't need to do anything but the service. Unless dood has done this recently and can prove it, you'll want to do the service. And that is precisely because birfs are expensive.
Headgasket. Look at the FAQs but also look for "weeping" where it looks like minerals oozing Yosemite-like at the head and block. If that goes and you get Robbie to do it up, I dunno $2000 to $2500 (?) but you'll get new hoses, t-stat, serviced injectors, new radiator, and a rebuilt head. And you'll never need that again. I didn't do this and won't probably until I get some undeniable evidence it needs to be done.
Baselining: All the fluids. Tranny, diffs, tcase, brakes, at the minimum unless dood can prove he's done these recently. Rear bearing repack, pretty cheap actually; $100 for labor-ish. Tune-up (plugs, wires, cap, rotor, pcv); do it yourself for $200-ish. Maybe drop the axles and futz with the ujoints to make sure they're good. Belts; $25. Little Heater Hose; $100 for labor. And there are tons of threads on baselining.
The front end and the head gasket are the big ticket items that have higher (not likely per se but HIGHER) chance of getting at your bank account. After the baselining that I listed it is like any other older vehicle. I expect the components to be a standard deviation or two longer lived but still, an alternator or oxygen sensor or power steering pump is gonna fail.
I've had nothing fail and it sounds perfect and nothing is on the radar. I expect actual maintance to be in the hundreds per year and over the next 10 years I expect to spend $3000 on repairs. But my rig has 133,000 and I drive it about 7,000 per year so I don't think I'll need a motor or tranny in that timeframe. But even if I did, it would be inside the depreciation of anything originating in this millennium.
Paul
This is a well thought out assessment.
It is ALWAYS cheaper to maintain a used vehicle than to buy a new one, absorb the depreciation and then eventually have to maintain that vehicle also as it ages. What do you do? Sell it and buy another new one so you can begin the process anew? That is just throwing money away.
I own two 80's. One that was neglected and has cost me more, the other which was maintained and has cost me less. The neglected one has resulted in a great learning experience, and not more than $1500 in baseline costs during the past three years.
Baselining is a necessary step with any used vehicle, which typically makes the first few months/years of ownership more expensive. But after you get past that, and begin to get a feel for the platform, you will settle in to a schedule and it is very manageable.
Bear in mind, an 80 is a world class vehicle. An heirloom quality machine on par with the best the world has to offer. Unlike other vehicles which are essentially "throw away", a Land Cruiser has been engineered to last. Don't quote me on this, but I read somewhere on here that the 1FZ-FE was engineered to tolerate TWO degrees of overbore on the cylinders for rebuild, estimated to be around the 300-400,000 mile mark. If Toyota designs a driveline to last a million miles, then the rest of the vehicle must be able to go the distance as well. You will find that the TLC is up to the challenge.
Now different folks have different ways of defining value. The above argument only makes sense if you are a content person. If you appreciate TLC's to the point that you are willing to commit to them and are in it for long term ownership, then the long term investment makes sense. If you get bored easily and want to change vehicles every few years, then the above arguments do not apply.
I know you recognize this, but perhaps this is the angle you want to take with the wife. You desire a vehicle that has unmatched quality, that is safer than just about anything else out there, that over the long haul is really a sensible and frugal choice when you consider the cost of long term ownership.
You will be hard pressed to get anything for $17k that approaches the quality, safety and value that you get with a used 80 or 100 series Cruiser.
JMHO. YMMV.
