- Thread starter
- #21
hey i also used the walker but its not working properly again the engine light is onI am in California - used these O2 sensors and passed smog with them.
My light is on too but it's the little valve under the upper intake plenumhey i also used the walker but its not working properly again the engine light is on
currently my mechanic used walker brand o2 sensors, still that one is not working@dense
I also have a 94 LC and currently have the 25 & 26 CEL, no drivability issues. I just changed the plugs that had about 25k and the plugs look normal.
This is my second set of O2 Sensors, the 93 & 94 can only use the Toyota sensors 89465-69115, everything else with not work. My mechanic said the problem is the heater element on the O2 sensors.
If you are willing to wait for the O2 sensors and get them from over seas
Loading…
www.amayama.com
any idea where i can buy the OEM o2 sensor for the 1994My light is on too but it's the little valve under the upper intake plenum
Check with Toyota? I'm not surecurrently my mechanic used walker brand o2 sensors, still that one is not working
Part number is 89465-69115 for both of the O2 sensors on a 94. It has a long pigtail but can be used for both locations. I got mine from Partsouq, but you can get them from the dealer as
is that the partnumber for the 1994Part number is 89465-69115 for both of the O2 sensors on a 94. It has a long pigtail but can be used for both locations. I got mine from Partsouq, but you can get them from the dealer as well.
thank you so much , i try to find it on the dealership but its out of stock everywhere, do you think the partsouq ships itYes, that is the part number for the 94.
It shows out of stock on partsouq as well. I would call your dealer and see if they can locate it in the warehouse. That is typically what I do.
is that the upper onePart number is 89465-69115 for both of the O2 sensors on a 94. It has a long pigtail but can be used for both locations. I got mine from Partsouq, but you can get them from the dealer as well.
its is also out of stock, its not available anywhereThat is the only one you can get, so it is used for both locations.
Currently OEM pricing delivered for one to my door step $119the connectors on the loom side can also need replacing depending on age/mileage/condition.
can you please send me the linkCurrently OEM pricing delivered for one to my door step $119
