Can the lack of memory seat settings on the OT and OT+ be confirmed?Airing my grievance that the OT does not have memory seat settings. Annoyed that they left that off. I have heard that the OT does include power tilt and telescope steering wheel though![]()
OT+ has it. OT does not. According to one person that took delivery of an OT, it does not have memory seat settings.Can the lack of memory seat settings on the OT and OT+ be confirmed?
Reference: Log into Facebook - https://www.facebook.com/share/mNQhMXYHgib7c11s/?mibextid=K35XfP
job Pics are great...Thanks!+more.
I personally ran a full set of 1/4” aluminum skid plates on my Tacoma to keep weight down a little bit (+ BAMF sliders and a high clearance steel rear bumper). Dragged them across many rocks and they performed and held up great. Personally I’m planning to run aftermarket aluminum skids as the Lexus ones are fairly thin. I think they would work for 99% of the world that would never try an obstacle or trail that has significant risk of high centering.
The first customer LC250 First Edition was parked in front of the Toyota side of the house. I is a customer truck so was not open. I did get a good look at the rock sliders. They appear sufficiently beefy with reasonable attachment points. I’m sure Toyota did plenty of math on the bolt clamp loads and Finite Element Analysis to be confident.. Very, very few GX or LC250 will become rock rigs so the Toyota sliders look up to the task of protecting the rockers. I do wish they had a rear kick out. Unfortunately I did not get pictures.
Additional edit comment. The aftermarket will make sliders that are both stronger (more lower attachment points across the frame, bigger hardware, stronger/thicker DoM material) and better (kick out, fill plates, 0 degrees so some utility as a step). Not saying these are as stout as the aftermarket. If you are a frequent brasher of rocks or frequently traverse gate keeper type obstacles the factory sliders are likely not for you.
Those Toyota engineers are incredibleThe radiator even healed itself. Amazing new tech!
Isn't there a separate coolant circuit for the inverter? My guess is that they snapped a coolant line for the inverter's coolant circuit, hence the small amount of leakage, and the vehicle driving long distance without repair.The radiator even healed itself. Amazing new tech!
Throttle House LC250 Review.
They at least mention / explain the Prado factor early on. I thought it was an entertaining review...
I think they are just entertaining car reviewers with no real knowledge of the Land Cruiser platforms. All they did was regurgitate Toyota’s talking points on the new Prado. They also proved how cheaply it was made by referring to the interior as cheap, underwhelming engine performance and the way the door sounded when shutting. They never even bring up how it compares the LX600 in their recovery team. In the end they pretty much say just buy the 4R or GX unless you just have to have the Land Cruiser name *cough Prado*!
