Largest tires on stock 100
nc
Can anyone post a picture of a stock 100 with the largest tires possible. No rubbing. I know to look it up but I can't find pic or a definite answer on size. New to 100's
295/75/16. No rubbing
picture.php
General consensus on this website is 285/75/16 with no rubbing and no lift, however as 2000UZJ said, once you get a lift you can easily fit a 295/75/16. There are countless threads on this forum with this question, do a quick search and you'll find more information than you'll care for!
FF
I've got 33x12.5R16 TRXUS MT's on mine - no lift (yet) and no scrubbing.
Sorry but this is the only pic i could find at the moment
Thanks. I have a new set of 33"BFG's on my 80 I might swap
Does any know of any side effects to adjusting the t- bars. I have a set of 33 bfg's I'm putting on. They shouldn't rub but I might try to get a little more hight
2000 80k miles.
2000 80k miles.
Search torsion bar and you will find plenty about this. You will want to adjust, make sure droop is okay and get an alignment afterward. There has been exhaustive discussion in this by previous folks....
6" pro comp lift. Do it. If you haven't searched yet, general consensus is 285/75/16 will be fine. And as stated, you'll want an alignment after you mess with the front. 30mm socket and breaker bar are your friends.
