landcruiser trailer ?
washington
new to the trailer thread.
i want to build a small on/off road trailer like i have seen on this and other sites .
i want to tow it with my 2002 landcruiser and i hope to use the same rims as the cruiser .
does anyone have a sorce for a axle with the same bolt set up or is a junk yard the way to go ?
i would rather start with somthing new.
thanks for any input
Jonah, it doesn't say where you're located on your signature. 5x150mm are commonly available in Australia (100, 75/76/78/79 & 200 all use it), but they're impossible to find in the US. You could also get 6x5.5" hubs and have a machine shop weld up the stock holes and redrill them. Otherwise, as David pointed out, you have to go with adapters.
thanks i will use adaptors and some standard axle
jonah, depending on where you are located, you can check ABC trailers, or Southwest wheel is a good source for custom axles. I had Henderson wheel in Salt Lake City build mine since they are local to me. There are several good sources for axles. I think if it were mine I would build the axle 3" shorter than the intended track with and use some 1.5" spacers. Good luck.
so far all i can find are some 5 on 150 by 5 on 4 addaptors and they want 90 bucks each.
do you all think thats a ok price or should i keep looking.?
thanks
