Installed this evening. Not much to it, but I feel like starting a thread.
I chose this product for a couple of reasons. Firstly, my carpet was not faring well as a tailgate cover. This is due to moving things in and out, standing on it to get to the roof rack, and just general wear and tear. I considered a storage option (a la Wagongear), but they haven't been available for nearly a year now. Additionally, because I have the factory swing out and associated latch, the majority of the interior of the tailgate is taken up by bracing for the landing pad/catch. I'm also not convinced that the hinges/hinge mounts are up to the extra potential weight and I don't want to have to lift it when I close it up.
A few notes:
Very happy with the product so far and I don't see that changing in the future.
Center and mark
And complete
A few notes:
- If you have the factory swing out you will need to cut down one of the bolts and trim the "wings" of one of the toggle nuts. The reinforcement for the tire carrier latch reduces the depth behind the panel for one of the fasteners.
- Be sure to align the toggle nuts with the flat area of the tailgate before pressing into position. If you don't do this the ribs will not allow them to open.
- The best technique I found for getting the toggle nuts to seat was to press them through then shake the panel side to side to flatten them out and allow them to grab.
- You will need something to apply upward pressure when tightening the fasteners. I used a trim removal tool.
- Be careful not to unthread a fastener from a toggle nut when rotating into position. If it falls off, you will need to remove the whole panel and then fish around with a magnet to retrieve the nut.
- An electric screwdriver is highly recommended.
All in all very simple to install even though the toggle nuts can be frustrating until you get your technique down. Due to how simple it was to install I didn't take many pics. Back area of the truck is also currently under construction, so things are a bit of a mess.- Be sure to align the toggle nuts with the flat area of the tailgate before pressing into position. If you don't do this the ribs will not allow them to open.
Center and mark
And complete
