Hey guys, I truly need some expert advice here. I'm currently upgrading my alternator from the stock to a 130 amp, I'm just unsure about how to wire the charge cable.
Does the charge cable go directly to the battery or where is it supposed to go. I am not changing the oval plug, but I am unsure on how to wire the alternator since I have to upgrade the cables.
On the negative side I noticed the cable that goes to the block and there's on right behind it that connect the block to the frame. is this correct?
Thank you ahead of time!
