......Just a point of clarification, the FSM lists 53 ft-lbs as the torque spec for 6T Hex head bolts (Studs were not listed). I spent a few hours searching for a torque spec for studs and not bolts and was unable to come up with anything. Also called a few of my engineer buddies but none of them were aware of any torque spec table for studs either. Closest we came was a torque spec for an unknown material/class 2 for 1/2 inch bolt was ~40ft/lbs. I had asked about this as the knuckle appears to be cast, however the 40ft/lbs was for a bolt and not a stud.........
There may be a bit of difference between the '97 FSM and the '94 FSM Standard Bolt Torque Specifications (although I can't see why). My '94 SBTS section is 2 pages. First page is a chart which lists Hex Head Bolts, Hex Flange Bolts, stud bolts and welded bolts with a chart to identify each for the purpose of determining the class of each. Second page lists the specified torque for each class from 4T to 11T. The break down for each class is by diameter, pitch, and whether it's a head or flange bolt. Flange bolt is a higher torque rating, so using the head bolt rating is leaning to the conservative and IMHO more accurate rating for the stud bolts. I also believe if there was a deviation to this standard for the knuckle studs, Toyota would have published it in the FSM in the Suspension/Axle section. Especially owing to the fact the change in design from the old style (pressed in studs) to this newer, more versatile style.
