Knuckle/Steering Arm Bolt Torque Spec Needed
Cardiff BTS & Tahoe
I'm replacing the bolts at the bottom of the knuckle that attached the steering arm. The ones with the cone washers.
I have looked in the FSM and searched and can't seem to find the torque value.
Thanks
It's in there.
Good idea to throw at least some blue thread-locker on them too. I used red after reading several accounts of them falling off and causing lots of issues.
There is no torque value for that, should not be torqued. If you apply force, you may damage the first thread.
I take the studs to where they are tight right when you feel them get snug, I use no loc tight and have never had an issue with new studs doing it like this. Torque the nut to 70.... I will also take paint pen and mark the stud to nut to see if either has moved
I think it might be 15ftlbs for the stud you can look up the stud in the fsm which till you its torque some fsm have a torque guide for all the bolts usually in the back
New style studs have a torqs head you don't need to double nut, if you didn't have the torq head on the stud then double nut like he said
I don't use loc tight never had prob if you seat them then the nut will do the rest take um to 70 ftlbs, then check the nuts after few trips , good habit to always look at them when you get gas or wheel. I did have some loosen on my truck years ago and just pulled them all and used all new hardware and they have been fine
FWIW, in most cases a threaded connection reaches full strength when the threaded part reaches a depth equal to it's width. In other words, when your 10mm stud is inserted into the threaded hole 10mm deep, it has reached full strength potential. Threading it in further doesn't help strength, although it may be necessary to position the stud shank properly. The stud will break before the threads tear out. This assumes the stud and hole are the same material. As Inkpot and others said, the torque is applied via the nut. Be careful using loctite, if you allow it to set up before you tighten the nut, it will create a plastic bridge between the threads, preventing metal-to-metal contact. This plastic bridge could compress over time, leaving your assembly loose. If you use loctite on the nut as well, you can never get an accurate torque reading on that fastener again. Once it dries, you will be measuring the torque applied to the fastener plus the resistance of the loctite. That doesn't tell you how well the parts are being drawn together. Some assemblies require that, most don't.
I periodically check my steering knuckle torque values, usually at oil changes or when I'm under the truck for maintenance. I just set the wrench for the correct value and try to tighten the fasteners. If all is good, the wrench should click before anything moves. If something moves before it clicks, I know I need to keep an eye on that fastener. If it moves and never clicks, I know it's time to cry and start looking for a Helicoil kit.
Those studs/nuts do get loose occasionally, I assume from the extreme duty or from beating on rocks or whatever. Problems come when they are left loose, allowing the assembly to shift around. That's when threads get stripped and the knuckle falls off while driving. We've seen it several times around here. Not fun to repair on a trail.
Resurrecting this thread, because the installation torque isn't specifically listed in the knuckle assembly procedure. However, the torque for a non marked M12 stud (4T) is 35-lb·ft (for a hex head bolt; the hex flange bolt is higher at 39-lb·ft, due to the flange). That's what I used.
These are replacement studs with the E12 drive instead of the Ø10-mm boss on the exposed end. Given that the knuckle housing has had 200k miles on it and been subjected to stud installation before, I was leary about using the 6T values. Although, given the application, that's probably what they are. They come with green threadlocker on them, which really screws up the torque feeling; they felt like they were yielding at 35-lb·ft.
