Knuckle rebuild for first timer.
Northeast Ct
Looking to rebuild my knuckes. I've had the 80 for a couple months now. Not a daily driver or anything. But one is leaking badly, who knows the last time they've been touched. Wanted to check grease level, but couldn't even get a wheel off yesterday. (Think the hub is just Frozen on to the rim.)
Was trying to kick the tire back and forth pretty good. Couldn't get it to move. Tried to get bunch of penetrent in there, see if it makes a difference.
Anyway just curious if there's any tips, how long should I be looking at per side having not done it.
I imagine I should just get bearings aswell.
Anybody have part numbers for the bearings needed for each side? Including wheel bearing. I just don't want to start and forgot to have gotten a certain part or peice.
it took me about 1.5 hours, for 3 nights for the first side. it took me 2.5- hours in 1 night for the second side. I also did new brake rotors, pads, and hub bearings at the same time. I am somewhat mechanically inclined. I have experience with my previous LC 100's doing bearing, brakes and other stuff. I was working in the garage on the floor. I had all the proper tools with the exception of a "seal puller". I was able to manage with a crow bar. There are a few videos online. watch them over and over and over. Its not that difficult, just many steps and time consuming to do properly. Make sure you have all your parts before starting. I thought the kit I had purchased through Nitro gears had wheel bearings, it didn't ( my mistake, not theirs) that being said, I'm a little worried about you if you couldn't get the wheel off. I spent about $160 on a knuckle kit?, another $85 on hub bearings, and 180 for a brake kit. $20 on grease. I rented a seal setting kit for free from the local auto parts store. That was crucial in my opinion. Good luck buddy, take your time. oh yeah, its a nasty, dirty job, buy a box of nitro gloves and a roll of paper towels, change gloves and use as many paper towels as needed. oh yeah, I also bought a used parts cleaning table for $50 on C-list. I think that a huge help to.
You young'uns ought to be able to do searches and stuff......
I did mine for the first time earlier this year. It was an 8 hour job to complete both sides for me using the instructions from Cruiser Outfitters and OTRAMM's YouTube videos. A lot of that was cleaning parts and removing some stuck spindle nuts that I ended up cutting off. The kit from Cruiser Outfitters had everything I needed except the spindle nuts.
Good luck! It's a satisfying project to complete.
buy a kit from @cruiseroutfit and get new rotors at a minimum. if you have the extra coin buy some reman calipers from napa and some brake lines while you are in there. take your time and have some jackstands. its not so bad just really messy. i can do it all now in about 4 hours but i have done it almost 30 times now.
@slow95z 30 times??? what's the typical service increments for this?
I could of searched better, didn't want to steal to much company time. Lol
I feel like I'm pretty mechanically inclined. I've built about 10 cars in the last 20 years.
But the key word there is cars. Never had a 4wd SUV as a project car.
As far as the wheel being stuck, I've dealt with stuck wheels before. But usually I don't care about the wheel, and just hammer it from the inside. I just feel this one has really fused together.
When they leak??
Apparently nobody around me ever does it so I am the one guy everyone brings them to and every truck I buy to flip is leaking. I have also upgraded axles for people and done trail repairs for busted birfs and diffs.
Hang around the cruiser world enough and you will know.
Check for corrosion between the rim and the hub.
My truck had severe aluminum oxidation in there and I had to use an 8 LB sledgehammer (on the rubber parts!) beating on the tire from the outside to get the rim to finally come loose from the hub. (Full swings about 20 times each side.)
What year is your truck? Different years have slight nuances of differences.
And....it's I could HAVE searched better........not I could of...... :rofl:
Below is a link that you may find helpful before you start your rebuild, it comes with lots of photos. Oh, one more thing, if your a 20 or 30 something you should be able to knock out both sides in a single weekend. Now if your over 60, you better plan on 2 weekends to complete the job.
x3 buy your parts from Cruiser Outfitters. Very complete kit at a good price and it comes with some instructions. Took me probably 8 hours the first time around.
