- Thread starter
- #21
Brake rotors arrived this morning! Got them installed along with the tie rods and stabilizer.
In my defense of ownership, this truck drove and steered the best!Steering woes I believe are the result of compromised trunnion bearings and worn out tie rod ends. Getting both in order. The TREs were so frozen I soaked with PB Blaster overnight and torched them... no success. I finally had to cut two of the joints and weld a large nut on each so I could get them out with a 6 point socket and long breaker bar.
compared to the two 60's era FJ-40s? You bet.
While replacing the rocker cover gasket, I decided to clean up the throttle cable as all the plastic coating was cracking or had already fallen off.
I slipped a length of 3/8" electrical shrink tube over the exposed cable sheath, and it worked well to seal the exposed sheathing.
View attachment 2588450View attachment 2588451
After an extended ride in Kitsu, I copied FJBen and added 3" of leg room. Thanks FJBen!I’m 6’5” and moved my seat back over 3” in my BJ74. I just judged some 1/4” flat stock and it was easy and helped a ton.
Hello,That makes a huge difference in comfort.
I've ordered the Cruiser Outfitter's medium suspension kit but the front springs and shocks are backordered till mid-March. While I wait, I'd like to see what your ride height looks like with the medium load package installed. With the medium springs in the front and the heavy springs in the rear, you had 5" from fender to top of tire in the front, 8" in the rear. With the Ironman shocks/springs currently on my KZJ71, I have 8" and 9". So I'm looking to see how much improvement comes with the medium package. ThanksIt came with the kit, but I'm in mid knuckle rebuild so haven't installed it yet.
Part number OME SD24
I'd measure from the center of your hub to the fender-eliminating the difference in tire sizes. This morning I measured 21" from center of front hub to bottom of front fender and 22 3/4" from center of rear hub to bottom of rear fender. I currently have no rear seat or additional weight in the back and anticipate the rear will be lower once loaded.I've ordered the Cruiser Outfitter's medium suspension kit but the front springs and shocks are backordered till mid-March. While I wait, I'd like to see what your ride height looks like with the medium load package installed. With the medium springs in the front and the heavy springs in the rear, you had 5" from fender to top of tire in the front, 8" in the rear. With the Ironman shocks/springs currently on my KZJ71, I have 8" and 9". So I'm looking to see how much improvement comes with the medium package. Thanks
thanks so much, that does help. From hub center to bottom of front fender I currently have 23", nearly 24.5 in the rear. And your measurements were with medium springs front and rear? I too have removed the rear seats and have no load at present. Out of curiosity, what are you running for tires? Mine came with some Cooper 265/70 r15's. thx again, SteveI'd measure from the center of your hub to the fender-eliminating the difference in tire sizes. This morning I measured 21" from center of front hub to bottom of front fender and 22 3/4" from center of rear hub to bottom of rear fender. I currently have no rear seat or additional weight in the back and anticipate the rear will be lower once loaded.
Hope that helps!
Cheers
Greg
I have the medium springs in front and rear. For tires I've currently got BFG KO2 in 235/85 r 16. They were new when I purchased Kitsu, otherwise I'd have gone with Cooper ST/Maxx, probably in 255/85 R16 like I have on my FZJ80.thanks so much, that does help. From hub center to bottom of front fender I currently have 23", nearly 24.5 in the rear. And your measurements were with medium springs front and rear? I too have removed the rear seats and have no load at present. Out of curiosity, what are you running for tires? Mine came with some Cooper 265/70 r15's. thx again, Steve
