The ECU can regulate fuel pressure, but it does not directly "monitor" fuel pressure.@jonheld, does the ECU need a permissive from the fuel system to initiate spark system or are they totally independent? In other words, since my fuel pump is disconnected, does it somehow prevent the spark generation at the distributor? If so, I need to get the fuel side sorted before chasing down spark.
There is no OBD2 code for fuel pressure on this vehicle.
There is no OBD2 code for fuel pump on this vehicle.
The ECU doesn't "know" that the fuel pump is disconnected.
Pulse generation at the distributor is completely passive. Magnets passing by coils to develop pulses.
The distributor doesn't even get +12.
The igniter and ignition coil both get +12 and the igniter MUST be grounded to the bracket and bolted in place.
for her trusty foot and flushed, bled. Brakes feel great now. Took it for a spin and ABS light came (not flashing, steady) on as did the check engine light. Need to look into that! Truck is sssooo smooth! No power issues despite MIL.
