key will not turn in ignition
1996 LC, the ignition seems to be quite bound up. The key will not turn the ignition. I have had this happen when wheels were turned, but they are straight on sitting in the driveway.
I have tried the "steering wheel jiggle, key turn exercise", also moving the key slightly in and out ( sometimes it works when pull back just slightly). I have tapped lightly on the ignition switch and also tried a small amount of lube on the key itself. Still won't turn.
And I don't have a spare key.
Any suggestions?
If you are certain the colunm is not locked and bound up it indicates a worn key and/or key cylinder.
In many cases a new key, cut to the original dimensions, will solve the problem. If you do not have the key code you can obtain it two ways.
1) Remove the key cylinder from the RH front door and read the code stamped on the side (IE W1478).
2) Go to a Toyota dealer service department with proof of ownership of the vehicle and photo ID that matches it.
Any dealer can cut a key from the code. If you go the pull-the-cylinder route I suggest you take it with you to test the key after it is cut.
Thanks- Made sure it was in park. Also did an override and put it in neutral. The steering wheel appears to be locked...I can move the steering wheel back and forth about and eighth to a quarter of an inch. When I move it to the right I can feel the ignition/key move. I think that if I could move it an eighth inch more to the right, I could probably unlock it. I'll need to try a new key at this point most likely.
Ordered my key- well keys. Only $7 each, so I decided to get two. I will post tomorrow and let you know the results.
i have solierd a skim coat on the key on one of my trucks then wiggle jammed it in . crude but worked. on my current truck i carefully broke the insides out , anything works to turn it now,but looks un butcharded, i still have to use the key for the door still.
Yep, tried the key both ways. Assuming with the new keys I am still out of luck, how big of a job is it to remove, or decouple the ignition switch from the steering column? On '80's TV shows it could be accomplished in matter of seconds.
You can change out the ignition cylinder as well.
To answer your question, however, it's not hard. If you have an alarm on it, you can use the wiring harness that comes with it and put in a switch or something to jump the wires you need to start the truck.
Do you need to step on the brake pedal while shaking the wheel and turning the key
Yes- tried stepping on the brake, not stepping on the brake, moving the shifter, overriding it to neutral then back to park, turning and shaking the steering wheel, lube, tapping lightly with a hammer, still stuck. I saw a post above about removing the cylinder, and I think you are right, not being able to move it into the ACC position may pose a problem, but I am not overly familiar with ignitions. Keys will be at Toyota Dealer tomorrow, crossing my fingers that it will work.
To remove the key cylinder it is turned to the accessory position and a detent pin is depressed through a hole in the housing.
If the cylinder will not rotate the pin can be driven in with a punch and hammer. This will, of course, ruin the cylinder but if it is alrady jacked it doesn't matter.
In order to insert the new cylinder the link in the housing needs to be turned to the accessory position with a screwdriver. The new cylinder is then turned to accessory and inserted into the housing until the pin locks.
Just a heads up, if you have the Toyota key code there are locksmiths who can cut you a factory key. I recently tried to get a factory key with the rubber on it, to distinguish it from all my other keys that look exactly the same. Long story short, Toyota didn't have those blanks, gave me the key code to take to the local smith, of course he didn't have the rubberized blanks either. However he could have cut me a new key based on the code.
You can also plasti-dip the top of the key as well.
Good News!
I had a set of new keys made, total out the door was $14.00. When I compared the new key to the existing one, they did not even look the same! I inserted the new key and the ignition, and like magic, the key turned. Thanks all for your input!
Oh and BTW, when I explained the situation with the parts guy at the dealership, he was convinced that it would not work and recommended re-keying the ignition.
I think we are a little spoiled by the knowledge of some of the parts guys on this forum. I have found ( at my local dealership anyway ) that the parts guys are not very knowledgeable about there product. The local parts manager is a particular ignorant whom I will no longer deal with. I knew I would have problems with him when he asked me what size motor was in my 97. I remember thinking " your the f-ing parts manager and you just asked me that " ?
I just called my dealer to ask for a new key to be cut and the parts guy told me that toyota changed its rules and will only allow the key code to be identified after a service ticket is made with the vehicle and title present. is that for real or is he just blowing smoke? having the same problem - seems like out of nowhere.
Absolutely real. The owner has to present ID and proof of ownership and the service department has to open a repair order before the dealer can request a key code. The request is run by Toyota through an instant check of stolen vehicles and the dealer must retain the repair order for two years. In addition after the request is transmitted a dealer manager must approve it before the code is transmitted back.
