Keep or ditch the doubler?
SoCal
As I get closer to wrapping up the drivetrain work on my rig I have one last "big" decision to make - do I keep or remove the NP203 crawl box.
My '68 rig will see street and light/moderate fire road use with occasional challenges thrown at it, do not see anything approaching hard-core or extreme use. Right now she has a SBC 350 crate engine with a TH350 transmission connected to a NP203 crawl box connected to a stock Toyota transfer case. The transmission / gearing set up is about the length of a football field. As a result my rear drive shaft is pretty short, and I am going to have some challenges in getting the shift levers and linkages positioned because of how far back everything is.
This has me wondering if I even need the NP203 in this build for my intended use - what do you think?
Too short of a drive shaft can create too steep of an angle and potentially cause issues with your U-joints. The crawl box is really nice if you are doing some more hard core off roading. It sounds like you will not fully utilize the crawl box with your intended driving. The benefits of a longer driveshaft will outweigh the need for the crawl box in my opinion. You could always keep the crawl box, just not install it. If you find yourself wanting to get into more hard core stuff, you can always install it. But for your intended use, I don;t think you need it. Just my opinion.
@Krondor - good morning and thanks for the response. That was my hunch, and since the drivelines are out etc now would be the time to remove it.
What do you think guys?
Great minds think alike. ;)
I have a 203 in my wagon and if I were doing it again I’d just do a single 4:1 gear in the transfer case. More simple, less weight, better driveline angles, etc
Glad I thought of this all by myself - ha!
If it’s not obvious I got some excellent coaching yesterday when I picked up the replacement differential.
Thanks Mark!
I will need some sort of adapter to connect the TH350 to the Toyota transfer case, is there a go-to Solution for that you all like?
Hi guys-hope everybody’s having a good weekend. Now that I have an approach down on the brakes I wanted to revisit this topic if I may.
If I buy one of the commercially available adapters is it really as simple as disconnecting the transfer case from the crawl box and then removing the adapter and then just putting the new stuff on?
This will be my first time goofing around with one of these adapters and crawlbox so trying to figure out if it’s a bigger than a bread box job. If I gave myself a couple hours and had a helper does that seem reasonable?
@Lil'John -She is a 1966 FJ40.
I don’t know if the tailshaft adapter for a stock tcase is the same as for a 203 doubler. I strongly suspect that it is not. And I believe that unless it is a spudshaft adapter, you would have to disassemble the trans to exchange it.
I would call AA and ask them. Their techs are very helpful. Or you could call Georg at Valley Hybrids. He sells a lot of AA parts, and he is a MUD vendor. ;)
Thanks gentlemen - I suspected that it was more involved. Sounds like a non-trival undertaking.
I will call the tech line, thanks for the referral as well.
Thanks @Lil'John , very helpful.
Will the gears want to come loose when I pull it apart, or just stick?
I guess the big quesiton is if I need to modify anything internal to the TH350, such as the shaft length.
@White Stripe is pretty close. You'll gain 2 1/2~3" inches at best. Total length of the 203+ the two adapters is just under 8"
The TH350 to tcase adapter is 5 1/4ish. The best balance of driveshaft lengths, in a 40, will always be a standard trans. A 420 or 465 if cost is part of the equation. Something like a NV4500 if you want modern + performance. The auto will present problems due to their
length. Relocating the rear axle back a bit is one solution or just living with the wheel travel and lift limitations that come with a short driveshaft.
It sounds like all you need is the TH350 which will allow a 18ish long driveshaft depending on your engine placement. I've got three of the doublers but all are mated to a split case. One is behind a 465 and the other two behind 700r autos. None will be in a stock length 40.
The 40 is lengthened 10". The front driveshaft is two piece, half carried above a skid plate, to avoid 30 some + inches of potential trail catastrophe
@White Stripe - interesting, need to figure that out. I thought that set up would be shorter. Good to check!
@lcwizard - thank you for the confirmation.
I am at a decision point here-I think what I’m going to do is just leave the set up as it is and focus on getting her driving. I think my next challenge is going to be setting up the controls for the doubler and the transfer case.
It looks like my transfer case has a vacuum lines coming off it so I will need to figure out how to plumb that.
Does the vacuum control the high/low or does the lever do that?
Thanks @Lil'John - yeah, I picked up on that after I had my second cup of coffee. OK, OK, it was my 3rd cup of coffee.
That just adds to my decision to leave this all in place and get it working as is. I found the vacuum hardlines, so now I just need to figure out how to plan that all together. Looks like it runs off vacuum from the engine and then is controlled by a solenoid?
@White Stripe - always with the details! Thanks for the reminder, the rear differential was dry which would have been a problem as well.
Thanks!
