SOLD Kansas City: 2003 Toyota 4runner Sport Edition V8 4WD - 272K miles, Southern Vehicle.
Status
Not open for further replies.
Overland Park, KC
Year
2003
  1. 4Runner
Mileage
272000
Color
Navy
For sale is a 2003 Toyota 4runner Sport Edition, 4.7L V8, 4wd - asking $5500 OBO. It was a southern vehicle until 2019, and has been undercoated before each winter with fluid film, so the frame and body have remained clean. It has 271,5XXK miles currently and is increasing, as it is my daily driver.
I’ve owned this vehicle for 10 years and for approx. 130K miles, and it’s been great. If it weren’t for needing something larger to pull a boat, I would have kept this and kept driving it. After baselining all the major maintenance items when I purchased it, it has been very reliable and never had major problems. I’ve kept maintenance logs in a spreadsheet, that I can share if you’re interested.
It’s well optioned, with moonroof, full time 4 wheel drive (4x4), and the reliable 4.7L V8(2uz). Being based on the landcruiser prado, it’s been extremely reliable and well put together. Even for it’s age it’s very quiet and doesn’t have any issues that would stop it from driving across the country.
Upgrades:
  • New Suspension was installed in 2018. Suspension was made KYB and for the FJ cruiser. The components can be used on the 4runner to give it a .5” true lift(no spacers) and improved spring rate.
  • Firestone Airbags Installed by 4WheelParts, new suspension was great for travel, but sagged under load.
Recent Service Notes:
  • New tires in 2019 ~ 10k miles on them at this point
  • Recent Transfer Case Service at Toyota Dealer
  • A/C compressor replacement recently
  • Refurbished OEM Stereo installed in March
  • New OEM AirMix Servo Installed in March
  • New Front Calipers and Brakes in March
  • New Windshield in March
Known Flaws:
  • It has the normal Toyota wear on the interior and exterior for its age, but would say mechanically it’s in very good condition.
  • Steering rack weeps when very cold. Since it only happens a couple weeks out of the year(didn’t do it at all when I lived in the south), it hasn’t been an issue for me.
  • Being a southern car, the sun was hard on the exterior and the paint faded on some body panels, clearcoat is flaking on roof and some plastics are faded.
VIN: JTEBT14R038008342
Here's the Mtc history for my ownership. You can verify the dealer service with Toyota owners website and the VIN.
2003 4runner Service Log
ServiceService DateApprox. MileageNotes
Brake Fluid Replaced06/2011
146000​
Preventive Maintenance - Completed at Toyota Dealer
Steering Fluid Replaced06/2011
146000​
Spark Plugs Replaced06/2011
147000​
Recommended NGK's were used
Differential and Transfer Case Service06/2011
148000​
Preventive Maintenance/Baseline. Mobil 1 75w-90 synthetic in Transfer Case and Valvoline Syn Blend in Differentials
Brakes - Front and Rear07/2011
150000​
Oil and Filter07/2011
150000​
Valvoline Full Synthetic
Tire Rotation07/2011
150000​
Replaced Passenger CV07/2011
150000​
Replaced due to torn boot - Replaced at Firestone Tire.
Oil and Filter10/2011
156000​
Replaced Headers and Catalytic Converters10/2011
159000​
Catalytic Converters failed and needed replaced to pass emissions. Full Headers were replaced at the same time, catalytic converters were in line with headers. Replaced at Toyota Dealer.
Oil and Filter3/2012
162000​
Full Synthetic
Cabin Air Filter06/2012
169000​
Oil and Filter07/2012
169000​
Full Synthetic
2 Tires replaced10/2012
172000​
Tires replaced at Firestone
Oil and Filter11/2012
176000​
Replaced Battery12/2012
176000​
Battery Everstart - Walmart w/3 year warrenty
Replaced Drivers side CV01/2013
177000​
Oreilly's Auto Part
Replaced Engine Coolant02/2013
178000​
Preventive Maintenance - Toyota Long Life Coolant(Red) Used
Oil and Filter, and Air Filter06/2013
181500​
Full Synthetic, greased driveline with synblend, replaced air filter
Differential Service08/2013
183000​
80W-90 Durablend Valvoline
Timing Belt Major Service and Transfer Case Rebuild10/2013
186000​
Water Pump, Timing Belt, Serpentine Belt, Fan Shroud, Thermostat were all replaced as preventive Maintenance. Transfer case seal leak, toyota rebuilt transfer case and replaced soft goods, changed fluid- completed at Toyota Dealer
Oil and Filter1/2014
187000​
Front Drivers wheel bearing replaced, Front brakes and calipers replaced1/2014
188000​
Noise from bearing - Calipers were sticking. Replaced at Toyota Dealership.
Oil and Filter06/2014
195000​
Full Synthetic
Idler Pulley replacement03/2015
199500​
New Gates Serpentine, New Toyota OEM Idler Pulley, New Toyota OEM Tensioner
Oil and Filter, Chassis Lube10/2015
206000​
Full Synthetic
Transmission Service01/2016
209000​
Transmission Flush and Filter Change, Completed at Toyota Dealership
4 New Tires06/2016
210500​
4 New Tires - Pathfinder AT's from Discount Tire
Alignment06/2016
210525​
Alignment completed post new tires
Oil and Filter, Chassis Lube06/2016
210880​
Valvoline Full Synthetic, Chassis Lube
Radiator Replaced and Coolant Change06/2016
210900​
Replaced Radiator due to leak, flushed coolant and replaced - work completed at Toyota Dealer
Oil and Filter, Chassis Lube12/2016
217000​
Mobil 1 Full Synthetic, chassis lube
Oil and Filter, Chassis Lube05/2017
223000​
Oil and Filter08/2017
229800​
Oil and Filter01/2018
236000​
Suspension Replacement/Upgrade04/2018
238000​
Swapped suspension for new FJ suspension, from KYB. Result lifted 4runner ~ .5 inch and replaced stock suspension. Also replaced both front half shafts with heavy duty/off-road(thermoplastic boot) versions from Rock-Auto.
Replaced Spark Plugs, Air filter, and cleaned MAF05/2018
239000​
Preventive Maintenance - Denso Iridium plugs used
A/C Compressor Replacement06/2018
241000​
Replaced Compressor due to failure - professionally installed, evacuated and filled with refrigerant.
Transfer Case Service09/2018
245000​
Replaced Transfer Case Fluid - Completed at Toyota Dealer.
New Brakes and Calipers09/2018
245000​
3 new Calipers and Denso Brakes
Oil and Filter10/2018
246000​
Full Synthetic - Purolator one filter
Oil and Filter12/2018
251000​
Oil and Filter, Chassis Lube04/2019
257000​
Full Synthetic
4 New Tires08/2019
260000​
4 Trailfinder AT's from Discount Tire
Airbags installed at 4WP07/2019
261000​
Firestone Airbags Professionally Installed at 4WP w/2 year warranty
Oil and Filter11/2019
263000​
Full Synthetic
Oil and Filter, Chassis Lube09/2020
269000​
Full Synthetic
Front Brakes and Calipers03/2021
270000​
Front Calipers Seized, replaced with NAPA Gold
Air Mix Servo03/2021
270000​
Air mix servo failed, replaced with OEM Servo
Replaced stock radio with OEM radio03/2021
270000​
Volume knob failed, found a refurbished OEM replaced it.
Sold?
Status
