Just got the Inspection back
She failed, as I supposed considering MD is an extremely tough state for vehicle inspections. The only major thing was the motor mounts
which I believe to be fine. If they do by chance need to be replace, which I highly doubt they do, does anyone have a price on something like this? Also, the person wrote in on the add. comments that there is a water noise when moving. I have noticed this but just assumed it was the gas tank because it is coming directly from that location.
Also, I have noticed when accelerating easily it shifts fine between all gears except it revs up a little high between 2nd and 3rd. Any ideas?
The water noise could be water in the rocker panels. I just read all about it last night. You can drain them via a plug in the bottom. There are tons of previous posts about it if you look around. Not sure on the other stuff.
There are 4 slits in the seam on the underside of your rocker panels. Those are the part of the body that is underneath the side doors (F&R). You can take a wire tie and poke into the slits and usually dislodge the mud and gunk that has clogged them. There is also a round rubber plug that can be removed to let them drain, then replaced. The slits should still be cleared or you will be doing this again when it rains.
-B-
How, exactly, do motor mounts "fail" a state vehicle inspection?
im curious of that also... they are not broken by any means, why replace them now? the inspection
process is flawed. Not all, but some mechanics with the license know they have you in a corner.
You want the inspection? Fix what I say needs to be fixed or I wont pass you. Want to take it some
where else and have the work done? Fine, but I will still fail you because you didn't let me do the work...
sorry to vent but I have been put through the fire with MD state inspections on several vehicles...
I used to live in Maine, and state inspection there is rough, and getting worse. We never had to inspect motor mounts, (I had my inspection license), but now they inspect brake lines very closely. Some inspectors will not pass a vehicle if the lines are rusty. And I don't mean rotting away either, just light scaling. It is all up to the inspector and his interpretation and mood.
I don't know if we are talking about the same state inspections, but down south all they look at is the VIN, odometer, and then they walk around the truck. Done.
There are no annual or semi-annual inspections in the great state of Alabama. What you are talking about is the verification that the vehicle is what it says on the documents when you get a title changed to your name.
yea its a mess, needs a reform. all the threads I read on the web say MD inspection is crazy. In order to get the vehicle titled you need the inspection done by a licensed inspection mechanic. they check a list of about 50 items in order to pass you. with out this inspection the dmv will not let you title and tag the vehicle.
on another note, i was able to find the plugs in the rocker panels and drain out all that water!
thanks for the help!!
Take the truck to another shop for the inspection. While the MD inspection is quite detailed unless the motor mounts are broken I don't see why he would fail you unless he wants to make money for unneeded repairs. I have had a number of vehicles inspected in MD and have never had any issues unless something really was wrong.
so took it to my mechanic, which I should have done in the first place but he doesn't have an inspection license. My initial plan was to get him to do the work, and take it back to the fools to have them re-inspect it. He let me know that he has a friend that will do the inspection and he will include that cost in the cost for parts/labor. All in all he quoted me $900 and this is with a tune up, fixing an oil leak he found and fixing the windows. This sure beats the $1500 to $2000 that the other place was claiming. Hopefully I can get this thing on the road this weekend. He also let me know that my motor mounts are perfectly fine....
