jsosh26.....76LandCruiser...SHUSH......
tcb said:
there is too much tech in this thread. two thumbs down.
Agree.
with post like Andy's this thread is in no danger of having to much tech
awesomeness
Hey John there is an article in this months issue of 4wd Toyota Owners Magazine about stock wheels and hub caps that can be bought cheap. Can't find the issue with the details or I would fill you in. The hub caps are super cheap from the dealer. Someone fill him in. I'll holla if I find the mag. I vote for stock wheels and hub caps. 33x10.5 tires will still look good on your truck with the lift. Remember, it's not gonna ride too good. It's a 40!
That has been my plan to get stock steelies and 33 x 10.5. Maybe we can find a group deal. Does anyone know when or if the 33 x 9.5s will be available?
33x950-15 is gone with the wind. 33x10.50-15 is your friend.
33x9.5's would look like crap anyway with the cut fenders and flares. Just my opinion but that would be awful narrow in that space.
Chris what's a 33 x 10.5 x 15 BFG at run for?
I may be getting some this month CL ad is blowing up. Maybe I should have asked more than $650.
If you want to come take a look at how my DUI is wired, feel free. I can't remember much about the install since it was a while back and was pretty easy other than a bad ground issue.
The truck turns over but hei is not producing a spark. 12 volts going into dizzy but no sparky. For you current dui owners the hei coil grounds itself through the housing correct? Or do you run a separate ground wire? The engine has a good ground otherwise the starter would not work.
I don't remember any ground wire. I'd go look but the 40 is under 3 tarps behind a gate that has a bad hinge. The next time I open the gate, I will have to replace both hinges and re-hang the gate.
I didn't see a ground wire on mine but it could be hiding. I see a dark green wire that looks like it goes back to the harness and a light green wire that goes to the firewall and I assume the tach.
That's power and tach
nice
this is an awesome look for tires and caps
chris will have my tires in Friday....ill probably try to put them on Monday.:bounce::bounce:
