well ok that was a joke, but I could dial it in tonight and then roll it down the driveway on fire??
hmmmmmfull coverage........im calling USAA because I pretty much have no idea how to fix my issues.
im reading tech and threads now and there are about 400 things to check im starting with learning about and doing the timing
in the parking lot if we discuss it.Did you mess with the timing since it was running last time? Got to be a fuel delivery problem.
thinking out loud
I did plug the fuel return line from carb to tank.....that shouldn't affect it though?
Why did you plug the return line?
Load it on a trailer. We can have a wrenching party at the Cherokee.
Check for fuel flow at the carb.
Fuel filter.
^^^^This......
Granted, I'm not there looking at it, but it definitely sounds like a fuel delivery issue to me. If I understood what you said, you said it'd run when you manually put fuel in the carb and cranked it, although it would only run for a short period of time? Like Bo-de-an said, check your fuel flow. Try removing the line connected from the fuel pump to the carb (don't know the setup without seeing it) Crank it a few times, and see if you get fuel out of the line. If you do, reattach it to the carb, crank it a few more times then go look in the throttle body of the carb while you're moving the accelerator linkage. You should be able to see the accelerator pump in the carb squirting fuel into it.
I'm wondering if whatever line you plugged might be creating a vacuum situation and not letting the fuel flow (sort of like trying to pull liquid out of an unvented container. At first, you can do it; however, with time, it'll build up enough vacuum where you can no longer draw from it. But, if it's vented, you can draw from it without effort...........) Again, without seeing it, these are just some initial thoughts
Is there gas in the tank?
Be sure to buy clear fuel filters so you can see the fuel filling and passing thru the filters.
the one ive replaced i did that at Jeff's suggestion....its kinda opaque...but you can see it.
the other one is after the regulator and was a PO one and it's in a brass casing so that will go clear after hitting the parts store.
