Might be a stupid question, but where does the large o-ring go? There's 2 grooves and I dont want to end up with a leak.
AGGGGHHH!!!!Just placed my order, seems like an amazing piece of hardware. Can't wait to get it installed. Now need to source a filter wrench... open to suggestions.
Amazon product ASIN B000N35ONCJust placed my order, seems like an amazing piece of hardware. Can't wait to get it installed. Now need to source a filter wrench... open to suggestions.
when installing an EZ Drain valve on the oil pan, does there need to be a the washer/gasket (the would be there for the normal pan bolt) between the EZ Drain and the pan? Asking because the EX Drain has an o-ring on it. Also, are the instruction supplied with the EZ Drain ("hand tighten and then another 1/8 of a turn") sufficient for the train plug since the standard is 30ft/lbs?
Good question. I have one of these waiting to go on at my next oil change. I would pick one, but not both. If o-ring, hand tight+1/8-1/4 turn seems reasonable. Otherwise 30ft-lb with a new crush washer.
