Joining Stainless Steel
Hi. I need advice on joining Stainless Steel.
I am a complete novice with welding and brazing although I have a lot of soldering experience. My current project involves joining 316 stainless sheet (3mm thick) and I am stuck.
Brazing with silver solder using a MAPP torch gives a strong joint, but leaves the steel thoroughly blackened and probably open to corrosion. Soaking the blackened joint in vinegar made little difference. I had the sheet pieces cut to order (probably laser cutting) and brush finished and in the final assembly there are hard to reach spots, so I am hoping to find a way to join them that does not require massive refinishing. The finished product does not need extrordinary strength or heat resistance, but will be outside, unpainted & open to corrosion.
Tin soldering is probably not strong enough, but I might try it as last resort & would need a stainless steel flux that works at low temperatures.
I see beautiful clean welds in industrial stainless construction items so it must be possible, but is there a way to do this without exotic tools and skills?
To maintain the corrosion resistance, you pretty much need to weld it with a similar filler. TIG would be my choice.
I asked a similar question not too long ago here.
Some replies discussing it, fluxes, gas etc.
tig, stick, mig, dual shield, take your pick.
for that gauge material, mig would be easiest to use. you will find that 316 filler, in any flavor will be rather spendy.
