It's good to be back!
I'm going to keep this story very short for the purpose of this post, I'll start a build thread at some point soon that'll be much more long winded...for now I'm just looking for info.
I've been a member of this forum since probably '05 or so. My first car was an '80 FJ40, I had 5 other 40's while I was a teenager and some Tacomas and other stuff after. My last post here was '13. Anyway, I've been looking for another 40 for about 8 years or so. My search had a few new developments recently, but I'll leave the details for a build thread...
Anyway, I snagged this abandoned project in south jersey... it's a '72 frame/axles (or, at least a '72 vin tag) with what I've identified as a malotte fiberglass tub. It has a th350 adapted to a factory 40 tcase, it had a shackle reversal done with some small lift springs, it has a con-fer auxiliary fuel tank, Saginaw PS, and obviously setup for an SBC, it also has twin shocks on all 4 corners.
I'm curious if I could track down the owner that started this project, it's got a couple interesting things done to the chassis that I'd like to hear more about.
Pics are attached, let me know if it looks familiar to any of you.
When I have more time I'll kickoff the build thread, probably this weekend.
Glad to be back!
Welcome back!
Good looking project, what are your plans for it?
I always enjoyed the tune port injected motors of the 90's. On a stroked 350 they produced awesome power and low end torque.
Nice base for a quick and cheap build :rolleyes:
find a rust bucket 40 as a donor for all the parts you will need to complet this project.
i like the tpi engine, but not much the alloy wheels and double shocks.
The old style SR in front is consider as rock finder but it's not worst than extended shackle , you can flip it if you want to gain some approach angle , but if you dont plan hardcore trail its ok like that
V8, Dual shocks and fiberglass tub scream: DUNE JUMPER!
Interesting. I remember seeing this for sale either here or possibly Craigslist a while back. I’m sure the po is on here. Good luck with the build and hope you located the old owner.
Here are some Gee Whiz thoughts:
1. Pay attention to electrical grounding options when using a fiberglass body.
2. Send us photos of your gas tank so that we can provide plumbing ideas.
3. Show photo of the adapter between TH350 and transfer-case, I just might have an affordable 700R4 option, which will give you a lower 1st gear, and an overdrive high gear- - -easy deal.
I'm way ahead of you, most of the pieces have already fallen into place for this puzzle, I'll start a build thread this weekend!
1. I'll be using a fuse box meant for boats produced by blue sea systems, it has a whole grounding bar built into the box. I used one in my '63 F250 cummins build and I love it.
2. I'll do that, but I think I'm going to go back to a stock tank, unless I'm convinced otherwise.
3. I'd love to switch to a 700r4, I'll send you a pic this weekend.
If you have the Con-Ferr tank, and it's in good condition, I could not conceive the reason to install a smaller tank inside the vehicle?????
Well, the aux tank has some rot on the edge that is visible. I suppose I'll likely take it out and assess the overall situation, I may just weld it up. The other issue is I dont have the plate/hardware that mounts to the body for the filler neck (I planned on just glassing up the hole), but if I choose to save the tank I can certainly fabricate that.
I'll consider my options on the tank.
Look at ebay #253750576879, third photo. That is my filler neck, but to use one of these you would still have to patch the very large hole in the side of your fiberglass body.
