Its called Loosechange for a reason
3ft from the sun AZ
...And this is what you get in the past 12 years of owning and wrenching just to Own and wrench
rear roof rack cats eyes for spots corner
rear spot kc on roof rack
corner roof NITRIDER 30 watt for immediate area to work around truck
need rock lights
Base 1972 Toyota FJ40 Toyota Land Cruiser (April 1972) Frame, clip and body matching numbers
original Front wing windows, need newer gasket around them however its a 68 front windshield frame.
Doors need new gasket around edge. Passenger does not mate. Re-drill hinge holes to work I guess
Need a good torque bar to rear end by ‘desert tools of az’
Autometer mini sport tach
Fabrication work - Gusseted frame and steering collar by RPM Fabrications (want rock sliders and skids and weld work on front pig)
6 gallon blue water jerry can and a Katadyn camp reservoir
350 Chevy conversion with shaved heads (245ft/lbs @ 2500rpm-50,000 miles on motor since rebuild)
HEI Distributor
New Toyota window regulators/cranks NOS
Aftermarket ignition switch from autozone (have original but needs a key made)
New wiper Switch NOS
XRP/Earls #8 aircraft hose and AN fitting for oil filter relocation (not installed yet)
Partial electrical wiring looming
Derale Duel row oil cooler with fan (not installed yet)
Have Transapapt oil filter relocation kit for this setup
Hitorque 4.2 HP small starter, installed but dopnt know if it works yet
Dbl Header gaskets by Eblebrock
High heat blanket for starter
16 gauge cut heat shield for starter (not installed)
Dodge Diesel Battery #2ga insolated cable starter wire
PPI External starter solenoid (not in use)
Block hugger headers corvette ls1 style
2-40 series dueled flowmaster mufflers
120 amp Hitachi one wire alternator internal regulator
#4 GAUGE silver coated alternator wire
Phoenix gold negative battery clamp
Front wheel two piston wilwood disk brake conversion
Wilwood 2lbs front brake residual valve
(Need Rear 2lbs residual valve)
Front DBA Gold slotted drilled and chamfered rotors
Rear DBA Gold slotted drilled and chamfered rotors
Windshield wipers NOS
need to hook up electrical to washer bottle,
Man a Fre rear single piston disk brake conversion
Original dual reservoir brake cylinder
Baer rear wheel brake adjustable proportioning valve
Iron pig off road Heavy duty rear diff cover
10-8.8 metric rear end carrier studs
New nos hood hold downs and hood rubber for clip
Have front grill hinge but no way to install.
New nos rear hatch handle
Working hatch rods for rear hatch
Working dbl rear swing doors
Rear LED reverse light
(Need swing away carrier)
(need to redo headers with new collector bolts and gaskets)
10 flange wip nuts
Blue torch fabrications Dual Battery box
(not installed and need Need PPI Digital mastermind isolator kit)
Yellow top Optima battery
Need aother battery
Extended #6 aircraft line/breather for valve cover-pvc
Auto-meter electrical volts and Water temp sending unit
New external electrical switch box with:
“6-waterproof 20amp 1.5 hp toggle switches and waterproof covers, 6-breakers, 10 gang fuse block with common positive and 6-30 amp 4 pin relays, main power in 75 amp phoenix gold breaker” for Fuel pump, MSD main, Msd distributor emerg cut off, Elec rad fan, elec oil cooler fan, purge pump for inner water bilge pump.
2-75 amp sollniods PPI one for relay to starter one and one for winch.
3” snorkel system of main pvc induction for external air cooler to carb (not for water fording per se, but cooler air and or limiter dust etc. (want to remover and stick into glove box)
K&N air cleaner
Soon to have h4 lights
SOR front Roll cage kit (not installed)
Aftermarket rear roll bar kit by Smitty-built
Rear roll bar pad
Three abc fire extinguishers -want to Buy “cold fire” system
Rear clevis (need to drop fuel tank skid plate to install)
Need to reinstall trailer hitch elecvtrical
Hella 300AMP emergency cut off switch
Uniden 78elite CB
5ft Wilson silver load CB antenna and
Cb antenna quick disconnect
Incline /Tilt Guage JDM)
3 ft secondary firestick CB antenna
Autometer Sport comp mini tachometer
Hilift, shovel, procomp strap, recovery equip.
Hi lift jack mount garvin wilderness
Upper spare tire mount to roof rack
Misc ammo cans for oil, tools, belts, hoses, fitting etc.
RCI puke can (overflow bottle)
Rancho 5000 rear shocks
Rancho 5000 steering stabilizerredo install inside of leaf spring area not in
between. Refer to picture
Rancho RSX front shocks
Warn locking hubs extra, warn premium locking hubs extra, Selectro hubs being used..these are the one before mile marker bought them out.
6 red saftety switches for all offroad lights, spots floods and rock, 6 fusable links and relays.: 1 road 5”rear offroad spots, 2 rear off road corner roof rack floods, 2 roof 30w lights rear backups, 2 rock lights, 2 upper roof rack front KCs, 2 bumper floods
Flow Kooler shortneck water pump and 185* thermostat
Edlebrock 1406 Carborator
Edlebrock aluminum radiator
MSD 6AL
MSD Sparkplug cables 8.5mm
MSD External REV limiter dial
MSD Blaster coil
Ron Davis Radiator
Black Magic Extreme 3300CFM electric fan with built in radiator shroud (mechanical on/off relay switch inside, not controlled by temperature of radiator
Rebuilt entire front axle end, bearing, wipes, races, etc. all re-done new hubs held on with studs not bolts
Locking hubs with lacing bolts (need lacing wire)
ARB pump
ARB front Locker
Rear Rebuilt full Detroit locker
Duel rear shock mounts already
available
Viair 400c pump
Firestone 2.5 gallon air tank for tires and or other apps
Viair small pump for airhorns
Haldley 130dB dual air-horn switch electric solenoid
Viair 1 gallon air tank
Have rear and front limiter straps (not installed, will need rear ear welded to install rear straps)
4 Leaf spring skid plates (only one installed)
Need ford shock towers
Extra Conn Ferr extended dog bones for leafs not using yet. Just extras
2-1/2” Dog bone lift
Advanced Handling Systems front end shackle kit (Needs reverse)
Super Duty front bull bar with D RINGS
Bellvue winch ( Identical to the 8274 winch)
External breather tubes for Axles
B&M Super cooler for power steering installed
Saginaw steering conversion RPM fabrication work done on it ... installed
High pressure Teflon insert power steering line
High pressure Earls low pressure side power steering hose
Downey 350 to3 speed transmission conversion housing
Centerforce Clutch
Original mechanical 3 speed transfer case
Transfer case/ tranny connection hose
May need new Chevy power steering pump
(Original ammeter doesn’t work in consule, however the fuel gauge does)
Radio delete cover is actually a volt meter and water temp gauge area
Galvin wilderness roofrack full length flooring’
Rear KC daylighters off road spots
5 MB motoring aluminum rims
5 Bf Goodrich ALL TERRAINS Ko 35 x12.5 x15
Need wire for glove box
Windshield is older than 72, using the 2 wiper motor setup. I use one wiper motor wired up to a switch at visor, since I haven’t tried to install both to see if they are timed right…I have 4 now,. seem to hard to find now
Rear Northwest industries 22 gallon tank with skid plate
Extended breather for rear tank
Original front tank I have 16 gallon Needs reinstalled I suggest RCI fuel cell and a Secondary tank switch)
Holly blue electrical pump (mounted to rear frame by cell, you may want to mount it somewhere else
Holly external fuel regulator-set at 7lbs.
#6 xrp fuel line from pump top carb
Oil can 40 microgram filter by pump.
(extra filter is in storage box under front seat)
I have an extra edlebrock rpm carb 800 cfm 1910 series
Led rear back up light
Led license plate light
Safety orbital leds tipped on cb antenna(looking for RED)
GPS GARMIN Oregon 550 (on my person)
Garmin 18 external GPS Antenna
Aces Netbook for garmin 18
GPS GARMIN eMAP (extra in glovebox for passenger for hiking, will sell with vehicle)
5 gallon jerry gas cans
Hilift jack mount to roof rack
Flashlight mount on tranny hump for Maglite
Rifle scabbard can fit on roll bar between seats
NEED new front driver seat
Need to install AA twin stick shifter
Need to route transfer air tube
Need to route tranny air tube
Need grab handle over glove box
Need door limiter straps (passenger door non operative)
Need swing away carrier (need ’76 bumper and taillights to work this set up
Need Drive shaft mounts for roof rack
Need new front drive shaft due to small twist in shaft
Needs speedo work/ cable seems to work
Front fender turn signal have rubber grommets to install xenon flashers (waterproofed)
Extra orange and red side markers
lenses and mountings
Extra fender turn signals
Gropro camera mounts and
3 gopro cameras (older model)
GARMIN roof mount antenna , howeverits magnetic so its on the hood
Acer laptop for GPS Software need laptop mount)
Two extra drive shafts with loops to hold to roof rack
Interior dome LED
Under hood leds for working on truck
Garvin roof with floor
straps and recovery equpt in bag for roof rack
What, no naked lady mud flaps? ;) Didn't go back over your list but apparently you've moved your gas tank, that or you need to add a gas cap to the list. Nice rig by the way.
And you're selling it for HOW much?
I can see where all your change has gone for the last 12 years...
I've not had to put much money into mine after the first 12 years... The next 12 will cost much less.
Oh yes the fire ext stickers are going to be moved.
Haven't found the 1st cav mud flaps yet i want.
As for the dents. What dents? I see beauty marks...and some battle scars . Hooah!
As for the paint, the most current is the 14th layer and is the freshest as of rattle can white 5 years ago. The other colors are just too obtuse to list. Canary yellow and fire engine red was one of them. home depot orange and black was another .but Halloween only last so long.
I think I have more stuff done I just haven't really sat down and figured it out.
I literally had the sheet metal screw sown the fiberglass roof into the gutters it was splitting. the actually rivets that hold the roof to the front channel have popped so I'm about the bolt that down. the roof does have a sun roof which doesnt leak HAha.
As for Selling? Everything is supposedly for sale in life. however not until all my ducks are in a row will I consider parting this beast out. its an extension of Me. most guys when older buy a nice hot-rod or corvette as a chick magnet... this vehicle is my chick "filter" not a magnet. let them see this and then they can know me. Old, kinda broke down, bulletproof and still going strong with history. me and the truck. well me for now at least. I need a rear end, and get the tranny I got for it installed.
thanks for the comments I think they are great whether they be critique or high fives
Oh BTW yes I do need the filler tube and the gas cap for the original tank.
However my original tank I picked up and the shield for free is from a JDM RH drive...so Im not sure if the tank will fit under the passenger seat of this Lefty,. will it sits there is a original cap there to cover the hole. seems neighbors like to flick their cig butts into the hole.
did I mention I have the AA twin stick. I just dont think I can use it or want to, I dont have a crawling gear at all., just all stock stuff, wish I could get at lewast 30:1 but I think its like 16:1. I need to reinstall my parking brake mechanism
