ITM camshafts
Tampa, FL
Has anyone purchased an ITM replacement camshaft from RockAuto, Klegg, JT outfitters or anyone else? If you have, was it drilled through both the 2nd and 3rd bearing journals to properly move oil to the rocker assembly in both pre-1975 1F and the later 2F engines? ITM uses the same part number for both engine applications. Unfortunately, the one I got was drilled through the 3rd journal for a 2F and not the 2nd journal for the 71 1F I rebuilt. RockAuto maintains they've sold many of these dual use camshafts for Land Cruisers and I'm the first customer to ever get one that wasn't drilled properly. Definitely my fault for not doing a new/old side by side comparison, but I find it hard to believe I'm the first to encounter this issue, according to them. Consequently, I've been told stick it up my rear end because I bought it over a year ago. Buy cheap and that's what you get.
I have never purchased a camshaft from ITM so I would not know. The two pictures below are from ITM's website. I don't think you received a faulty camshaft since the picture on their website clearly shows that the hole is drilled on the 3rd journal.
I pulled that detail up when I heard some of these cams were only drilled on the 3rd journal, but the vendor I bought it from swears they're doubled drilled for either engine, that's why they use the same p/n for both. I'm told they sell many of them. They say, I must have gotten a "defective" one but, because I bought it over a year ago, so it's TS. I sent an email to ITM's technical dept. to verify the actual drilling of this part number.
Oh then I must have gotten a defective one to it must have been a Friday tell you what just send it to me and I’ll drill it out for you or better yet I’ll send you the drill and in 10 minutes you’ll be done.
I have no problem with drilling it. What type of bit did you use and did you use a drill press? If I use a grinder to remove the heat-treated surface where the hole's drilled, how deep to do I cut? I guess I'll take the original cam and set it up in the press and see how it cuts.
Regardless of back story, you have to remove it to verify the actual cause of the problem. Could it be the bearing is incorrect, e.g. no oil passage?
A good Carbide bit, 650RPM in drill press and plenty of cutting oil and it cut through the original factory cam without a problem. Thanks for your sarcastic encouragement. It was a big help.
yes, it's on its way out of the block now. Way too much in parts and machining to tighten down valve cover and pretend oil will miraculously find its way to the rockers.
Same problem from Rockauto, took 6 months for the rebuild, no oil to the top end in a 1970 fj40. Oil holes in the #3 but nothing in #2. Expensive mistake on my part for not comparing side by side. Trying to work with them but it isn't looking good, 8 months...
Are those cams re-grinds? You can send them out to Delta Cam in Tacoma Wa. I’ve had several done, and they can do custom grinds, my latest is what I like to call a ‘half’ RV grind in a otherwise stock F. It’s just a tad higher lift than stock....just got to double check springs to make sure they don’t bind.
Anyway, you get what you sent them....back....and if you send them the lifters..:they will be resurfaced also.
My last F Cam was less than $100 for the regrind with lifers resurfaced and hardened.
I've been running a hydraulic roller cam in my big block Chevelle that I got from Delta Cams in Tacoma for about 10years now. Several other friends run their cams in various applications. They were great to deal with and very reasonably priced for the work.
I know....when I talk to them they are always knowledgeable and can provide good recommendations on application....they’ve done 2 FJ40 cams for me, the F above and a 2F....never an issue...and I’m quite sure if I got a soft lobe, or had other issues, they would make it right. Maybe not the labor to remove, but, re-machining, i’m sure they would make it right.
According to RockAuto, I'm the first customer this has ever happened to. You're right, we should have done a better job comparing new to old, but I see the assholes are advertising that ITM cam for use in 67-92's. They know consumers are a dime a dozen and they care who buys from them twice, but good luck. I drilled mine in a press with carbide bits and it's oiling very well now.
Thanks for your input.
Thanks for the great info.
No pics?? :p
At least post a link to the bits you used for the job...so the next guy who finds this post can benefit. :)
