fits great under my piggy hood.
That is beautiful! I'm sooooo envious!
Ok, still researching my 4BD1T swap into my 97 FJ80. Apparently a cummens 4Bt? will mount to an A440F trans from an earlier FJ80? If this is the case will the Isuzu mount to it as well? Could I put the A440F into my 97? Just trying to find a way to make this work
Rusty
97 FJ80
78 FJ40
dieselcruiserhead: Could you measure up the input shaft of the NPR 5 speed for me? I need to know the length, diameter, # of splines, and the dims of the little bit on the end that centers it in the crank.
Does anyone know for sure tthat the 4BD1 and 4BD2TC are balanced with the flywheel on the motor? I am trying to figure out if its possible to put a spacer between the crank and the flywheel. If it is balanced with the flywheel I would think that moving it is out of the question. If its balanced internally then it might be. Moving the flywheel forward would make it a whole lot easier to mate the H55F input shaft to a clutch disk.
I totally forgot that you were doing one... I can't wait to hear how it turns out!!!for an auto you could run the 700r4
it would be nice if I could avoid the $1600 in adapters though! Any ideas?
Rusty
97 FZJ80
78 FJ40
Does that tranny hold up with a motor thats half as powerfull as a Diesel?
Man Dougal, I just opened the model you sent me. You have been pretty busy! I'm glad to see that you have the motor side of the bellhousing in there. I have the automatic transmission bellhousing in a CMM right now. It has taken me a few hours to learn to use it but I think on Monday I will be able to get it done. Then to figure out how solid"works".
Good to see it worked.
I've done a lot more since then, I'm taking the opportunity to clean up the engine and paint anything that needs it.
