So last Summer the A/C went out in my Cruiser
Compressor wasn't turning on, so I hooked up my gauges and the pressure was a little low
We were actually on our way to the beach and there was no way I was going there without A/C, so I grabbed a can off the shelf, topped it off and it was good to go
I never liked the idea of using cans, so the next day I brought her into my shop for a proper servicing.
Evacuated the entire system, did a leak down test and it held vacuum fine for well over an hour, so I just put the proper amount back in and she was good to go again
This was the first time ever servicing the A/C in this vehicle
Fast forward to last Friday
I drove to work with the A/C blowing ice cold
Found parking, shut her down, clocked in and went back to the parking lot to chill for an hour before my shift.
Started her up, but she was blowing nuthin but hot air.
At first, I thought maybe she was overheating, but when I hooked up my scanner, she was right at 187*
Next thought was maybe she threw the A/C belt, so I popped the hood and all looked normal
When I hit the A/C button, I could hear the compressor turn on and see the RPM's change slightly, but still only got hot air.
Checked the lines going into the core and they were hot
At that point I said F'it and just went to work cause it was just too hot out to mess with it.
About 2 hours later, I came back outside, started her up and she was blowing ice cold again.
Drove her all of last weekend without issue.
I was thinking perhaps just a sticky expansion valve or sumthin.
Needed to go to a doctor's appointment this morning and decided to drive her since my daily beater has just enough gas to get me to work and back.
Drove about 20 miles out to the office and she was just dandy.
After my appointment, headed back home and about a mile up the road, the compressor started making noise and she was blowing hot again.
Pulled over and shot this video:
Looks like the clutch is toast
Gunna try spinning the compressor shaft when I get a chance, but just curious if anyone here has replaced the clutch assembly without pulling the compressor?
