Good points. Remote and bad comms with a compromised cooling system doesn’t sound like a good risk to take with family.gallon of toyota SLL is not an option, as i'd have to drive 45 min in opposite direction, to the dealer, potentially doing the repair TBD. I realistically have to drive 150-200 miles thru some of the most remote arizona desert in the state, no services, and then another 100miles home. Not towing, but huge, long hills. Ambient in the mornings likely 55 degrees, 90 in pm. Does going 60mph vs 80mph make a pressure difference on the cooling system? Could I use tap water in the short term, it'd be changed out pretty much at once? I get attempting driving it, but if it fully blows in the middle of nowhere, i'm in even worse shape, with the wife and mutts than now. Tbat said I'd much rather have this sorted out in Phoenix but not sure at what dice roll?
Maybe try one of the patches people have posted about in the big radiator thread. People that patch before the leak have had great results, and I think some people that patched an active leak even got temporary results.. though definitely double check me on that.
I still wouldn’t put tap water in it. They won’t necessarily flush the whole system, likely just drain enough to do the work and refill. Adding anything to the system that isn’t intended to stay just increases the work involved. And I can speak from experience in that fully draining the rear heat lines and core is not easy.
