is this a stock or aftermarket clutch
Golden Colorado
im thinking this is aftermarket and must have been replaced at some time
im swapping the bellhousing sobwas thinking of replacingbthe clutch but may sticknwith this one
thickness is 8mm
manual calls for 3mm for replacement
thanks
If I was that deep into the overhaul I would replace it with a fresh clutch kit. One less thing to worry about. Check the flywheel and machine it if it needs it. Make sure the disc goes in the right way! I just spoke to a guy the did a beautiful rebuild of a 45 and put it in backwards!
