is power seat alignment needed?
I just installed a set of power seats. One needs a new gear which I ordered. The one that still works has a slight side to side twisting or shimmy when I move it forward and back. I feel like it might be stressing the gears and motors. Is there a way to align it and get it all parallel using the two big bolts that turn the "screw" drives?
Or is this just a symptom that the gear is worn and on the way out on this seat as well?
I’m guessing you’ve already checked this if you ordered a new gear, but are the plastic screws in the side of the gears present and tight?
Check out Gamviti’s site to see what I’m talking about if I’m not making sense seat parts
I can’t find it, but there is a thread on here about the power seat mechanism and importance of having it aligned when replacing the gears. If I track it down I’ll post up for you.
Thanks. I have looked at the Gamaviti stuff and ordered gears and caps. I see that there stuff says to make sure that the parts are alligned. I guess I am asking if there is a proper and easy way to set up the alignment. I guess you could go all the way forward or back on both. But not really sure if the stops are accurate?
After reading a few threads it seems running the seat all the way forward as you said helps ensure they remain aligned when you pull the seat
Gamiviti seat gears, the aftermath !
Post #23 in this thread talks about a 12mm adjustment on the front side, not sure if that will unbind the mechanism for you. Might just need new gears as you queried
Seat won't move back, but want's to.
"My seats got out of alignment when they were on the bench installing the Land Tank seat extenders and I could not re-install them until I learned about the 12mm adjusters in the front of the seat that lets you adjust the two big adjustment right and left "screw drives" separately. (These screw drives run along the seat rail and are turned by the electric motor which drives the seats back and forth...the best way I can describe.) Warning, if you don't take the plastic gears out first they will strip them...but if your seat won't move but tries you may need to unbind the "screw drives" probably because the plastic gears are already stripped...just a hunch."
Replacing a screw cap revived one of my seats so I haven't needed to dig in further, yet. My long term plan is to go manual seats and not need to worry about this. If I could only find a set .....;)
I for one would welcome an alignment procedure, my new $40 gears already have a striped section because of mis alignment. I have searched and searched for an alignment thread and can't find method.
Can you pull the gears, run the seat/ “screw drive”/ worm gear all the way in one direction, then reinstall the gears in an aligned state?
I gave up trying to fix my power seats. Spent more money on new gears and replacement motors than I care to count . Contemplated getting a set if Corbeau seats but then then I got a lead on a set of manual learher seats from another '94. Picked them up yesterday so will start the refurb in a week of so. Hopefully my seat problems are gone forever.
Yep, the drive screws need to be in the same place when the gears are installed.
You wind them all the way, I want to say front, but it's the whatever end has the motors. Then eyeball or measure them. I did 3 perfectly and then have 1 off by a single thread. It still works, but isn't as smooth as the other seats.
Also, we plug in the harness and run it back and forth, confirm they are even, before installing the seat.
Deleted
