Is my Spindle Bad?
Air Capital of the World! Wichita, Ks/Choctaw, Ok
Experts:
I've been attempting to do the front axle rebuild over the past few days. I decided to tackle this due to the PS front wheel leaking grease on the rotor, so I figure do the whole thing. I've gotten the DS done and am on the PS. After some investigation of the inner wheel hub seal, I noticed that the spring has broken and must have be rubbing against the seal area on the spindle. The area that the seal is supposed to ride on is grooved multiple places and is very sharp at the 90 degree portion. So, do I need a new spindle in your opinion?
http://picasaweb.google.com/lh/photo/1KVMIhwaB2gquRy44tEgJg?feat=directlink
Thanks,
Mike
Mike,
The picture is out of focus and I can't tell. If it has deep grooves in it you might want to replace it. Surface scratches arent a big deal and you can attack those with an emory cloth
Ya, pic focus is a bid dodgy, but it looks as though it can be spiffed up with an emory cloth rubdown. Try it, what do you have to lose? At least it's an 80 spindle, not the crazy 1 piece spindle and knuckle in the hundy. Ugh.
Romer,
Here are some better pics.....I put a straight edge to give some idea of how deep the biggest one is. Keep in mind that there are multiple grooves, basically just seeing the biggest one in these pics........maybe I'll try again.
Picasa Web Albums - mgray24
Obviously, a new spindle would be best, but the seal only has to retain bearing grease, so it is not as challenging an application as with low viscosity lubricants. I would be temped to run it and see how it turns out.
