shocking
1. We do sell a license plate mount separately.
2. With the exception of about 4 ball bearing spindles (none of which worked, couldn't support the carrier adequately - to my knowledge all have been replaced under warranty) we have always used oil impregnated bronze bushings. Because the tire carrier does not swing wildly out of control with bushings like it does with bearings the stop catch is not necessary. You knew you were not getting a stop pin on your bumper, we discussed this in great detail prior to purchase.
3. We do not even stock a bolt in that diameter that is too short. I'm not sure how you could have received a bolt we do not carry, but I'm happy to re-send a set of latch hardware if necessary. This is the first I've heard of this, as always we stand behind our products and could have taken care of this easlily if we had known about it.
4. I see by a later picture that you have a LEXUS, not an FJ80. Our bumper is designed to fit FJ80's, not LEXUS. There are a couple years where the LEXUS had a different bolt pattern. If you had told us that you had a LEXUS and not an 80 we could have told you this at the time of your order.
Further, you should not use grease on the oiled bushings. If they require any lubrication a few drops of 3in1 oil will do the trick.
Lance
Iron Pig Off Road : Toyota 4WD experts
1) That would have been real nice to know when i placed the order.
2) This is a complete lie. I had no idea it would not have stop pins. It was on your web site with stop pins and never mentioned that it didn't. I found out when it showed up and never talked to you or cam in any detail about the stop pins. I just assumed it would be there. You have removed the text in the last 30 days from your site since i bitched to you about it.
3) Well you sent them to me somehow. They came in your box with your IPOR tape on it. Not that big of a deal if it was the only thing. A quick trip to lowes took care of it. It's just all the layers on top of each other.
4) I'm sure you will claim to never have gotten this email or recall anything else about my Lexus. That's fine, it's just good you guys are showing your true colors now in public.
Warn does or did make a 9.5xp with 125' of line. That is what i ordered and was NEVER told that it would be one with 100' of line. I have it in email from Cam. When i emailed you after it showed up two months latter you tell me they NEVER made one. All you have to do is google 9.5xp 125' and you will see it. Members on this board have one and it was on the warn site when i placed the order. You dealt with the problem the way you did when i emailed you. Offered no solution other than to tell me it was never made.
When i emailed you about the pins you tell me they are not needed anymore. But the friction of the bushing does nothing to keep the swing outs from going all the way around and hitting the body. You advertise one thing and sell another. Something needs to be done to stop the swing outs from hitting the body on your current design. If you are careful they don't hit. All it will take is one person to push the tire back too far and the corner panel is dented. This was never disclosed to me or other board members that have purchased this bumper. It's material change in design that you are not disclosing to customers paying good money for your products. If we had talked about this in detail before why didn't you point that out in the emails we exchanged. You simply told me to install it and that was how the new ones are.
You guys knew i had a Lexus and it's insulting that you are acting like it's my fault for ordering something that doesn't fit. I asked cam directly about this just to make sure. Even if i never told you this, it should all be part of your web site and/or your sales process during the taking of an order. It's really pretty basic. Then you want us all to call you directly if we have a problem so you can talk us out of having the problem, or tell us "You are mistaken, the 9.5XP only has capacity for 100' of wire rope" "you'll see what I mean when you have it installed" You know there is no way i'm going to send back a bumper from the other side of the country once it's all installed. What I see is the tire hits the rear corner panel at the light if it goes past 90 degrees.
I would be 100% satisfied if I got what i had ordered and you had advertised for sale as a retailer.
Fruthermore, If you put a single word of instructions people would know to use oil or no grease or whatever on the spindles. It rains like crazy in Oregon and bare metal rusts so quick I don't see how those would ever come off after a couple years without some grease on them.
Cut from my email account:
SENT 12/14/07
Cam,
I just wanted to remind you that i will need the "long
hardware" to go with that pintle hitch setup.
Look forward to getting all that good stuff. Let me
know when it's getting close and i will start tearing
stuff off my LX450.
THIS WILL WORK ON AN LX450 with the plastic still???
