Inverter location?
Friendswood, TX
I replaced the OEM head unit and no longer use the 6 disc chnager mounted in the console. Has anyone mounted an inverter in the disc changer location? The only issue I can think there may be in that location heat dissipation. Any other issues I may need to consider?
There is alot of info out there on inverter placement. Try using the search function for the 80 section.
I put mine under my passenger seat where the rear heater used to be. Others have put theirs in the rear quarter. There are other arrangements.
I did search for info on this. However, didn't find anything about mounting an inverter in this particular location. I saw lots of info for different locations, but, since this seems like wasted space and is in the perfect spot for access for laptops, phones etc. thought I would try it there.
Just curious if anyone has done the same...and if so, what their experience was.
I wired mine under the drivers seat, I considered running wiring from the inverter to a AC outlet mounted in the center console, haven't done it though. I think that might be a good idea, as the heat under the seat is not bad, but an outlet on the back of the center console would be very easily accessed by almost all seating positions.
I don't recall this being discussed before and I would like folks to throttle back on the do Search comments.
Seems like a good place for it. Make sure you have good ground and power and mount the inverter well so that the heat from the sae can dissipate into the base and into the metal of the floor. For smaller inverters, probably not as a big a deal, but always good design practice.
