Inverter power supplies use IGBTs (insulated gate, bipolar transistors) to derive a lower voltage, high current DC welding power from a higher voltage AC source.
Conventional old school buzz boxes use transformers to step down the voltage (and step up the current) and silicon rectifiers to derive DC power.
Inverters are smaller light weight and more efficient. Most welders are inverters now, so they are "regular".
Only at a maximum power of 20V and 100 amps and that is if the generator is accurately rated. You will find out when you pull the trigger if the breaker pops.
