Introduction with Question re 94 LC
Kailua Hawaii
Just found this site. First off let me just say that I have been enjoying reading through the forums. We have a 94 Landcruiser that has about 128,000 miles. Recently we noticed lack of power and very low idle with some stumbling - I changed the plugs; cap & rotor and intake hose and seems to run better but still idling very slow. I was told to advance the distributor and now it is advanced as far as it will go and runs alot better. Is there another way to adjust the idle? I am worried that I have the distributor advanced all the way. Does this sound like a timing chain issue?
Who would you recommend as a good landcruiser mechanic in Phoenix?
Thanks
k9k9 -
Welcome to the forum!
The need to advance the timing hasn't been reported too often on here. Have you considered taking a look at the fuel filter? It's relatively easy to change.
btw- I also have a '94 w/128k
Plug wires should be replaced at that age, it might solve the problem too. Stick with OEM.
Do you know if th fuel injectors have been cleaned?
Thanks for the replies,
I havent had the injecters cleaned yet, and unfortunely I used auto zone wires., How do I go about cleaning the throttle body?
In all the replies are there any thoughts about the timing?
Yes: Advancing the timing is only covering up the symptoms of the true root cause. IE, if all else is operating properly why would you have to advance the timing?
Yea good point and that was our theory also.
How do I clean the TB?
Im thinking I may want to buy a new FJcruiser, but just cant stand the thought of selling the LC.
I sure would like to get it runing good again, anybody in Phoenix know of a good LC mechanic?:confused:
:cheers: :popcorn: :bounce: :bounce2: :idea: Big Thanks again for the all the replies. Cleaned the throttle body and reset the timing back to normal - and she is running great again. Also decided to add Redline to the tank for good measure.
... and unfortunely I used auto zone wires.
I realize it is running better after the TB cleaning but you really need to use the OEM wires. We've had several reported problems related to after-market wires.
-B-
Thanks
For Phoenix-specific information, see the Copper State Cruiser club boards at the bottom of the main page.
And, welcome!
-Spike
