Introduction and thanks
Idaho
I wanted to say hi and thank you guys for all the posts I've been reading on a multitude of topics. I posted pic under the registry https://forum.ih8mud.com/80-series-tech/218093-80-series-registry-6.html
I guess I've been "lurking" for a bit. Recently got my 96 LX450 and have put the OME suspension on and been doing PM. Hopefully I'll be able to contribute back to the forum.
PM done: Oil and lube, flush/bleed P/S system (great write ups), fixed loose front wheel bearing but still have pulsing brakes (rotors worn uneven I suspect). Tranny was serviced not too long ago by PO as well as new brake MC and flush.
To do list: front rotors soon and maybe birflelds but may wait on birfields until winter due to time. Think I can reuse that oil seal on rotors if I do birfields later. ARB and winch, 285/75 on stock wheels.
Trouble shooting whining from idler pulley (alt) found that is the problem (read much on whining noises) way too much time tracking this down, thought it was the P/S pump but not. The new pulley squeals as much as the old (but it was shot) and Toyota is getting me another since they agree there is too much side play. I really think this pulley is unnecessary and may go with out it.
:cheers:
Which "oil seal" are you planning to reuse?
Trouble shooting whining from idler pulley (alt) ...
If you've read up on the alt idler pulley then you know that the cogged belts wil create a lot of noise. Are you using NEW Toyota belts? Are they tensioned properly? Are the belts routed properly?
-B-
Welcome!:popcorn:
Beowulf thanks for the feedback - to answer your questions--
To clarify I was hoping to reuse the oil seal that is on the truck side of the inner bearing that fits into the rotor. More of a hope than a plan really.
Yes I have read up on the cogged belts which these are. The way I isolated the problem was removed A/C belt still whine so not in those pullies. Removed two other belts no whine so P/S pump ok. Removed alternator idler pulley and reinstalled double belts no whine. I could spin the idler pulley and it would spin for about 30 seconds, bearings shot. The new pulley does have play, no doubt about it. But I found the A/C idler pulley had play as well but no noise from it :hhmm:. I did ask the Toyota guy about the noise with cogged or segmented belts (I read about here :D) he said shouldn't be an issue. Belts are tight but not to tight and in good condition. I actually started tight on the belts and loosened a bit and ran the engine repeated this several times trying to find the sweet spot of belt tension. The belts are routed correctly. I did think of buying new belts but didn't want to shotgun the problem. I'm planning on changing the pulley in the dealership parking lot to see what they say if it whines again. Maybe new belts if it still whines...
And thanks for all the welcomes :flipoff2:
welcome :flipoff2:
If we are talking about the same seal, that is the hub inner dust seal. You cannot reuse it but you can choose to *not* remove it if you don't plan to repack your wheel bearings. It is only about $15, maybe less.
I will stick my neck out and say that your "Toyota guy" is mistaken about cogged belts not being an issue with regard to noise in the 1FZ-FE.
If you have a new alternator idler and old cogged aftermarket belts and you still have the noise then you should put on a matched set of new TOYOTA alternator belts.
-B-
I got a print out of the Lexus manual and they call it an oil seal, same one.
If you have a new alternator idler and old cogged after market belts and you still have the noise then you should put on a matched set of new TOYOTA alternator belts.
Okay got a new pulley and it felt the same in hand and I actually was talking to to a tech at the parts counter. He came out with me while I installed the new pulley in the parking lot and when we started it, still the same noise. We took it back to his bay looked a little more and he was stumped but agreed changing belts may help. At $40 + I can deal with the noise for a while. I'm just happy it's not P/S pump :clap:. Just got my new bumper and that is where that $40 is going. I will be trying to fit my xd9000i into it.
CJF:
By the way did not try the WD40 but used belt dressing just as a check after I installed the first new pulley and there was no change in sound. I figured if the belts were glazed or hard the spray would quiet them for a short time. What's up with that pulley and belt combo? When I get new belts I'll repost the results. Thanks again for the feedback.
CJF:
Belt dressing does not work, in my opinion. PLEASE take two seconds and spray a little WD-40 on the belts. A good way to do this is to spray the crank pulley from underneath (with the brush guards removed).
I promise I don't mean this as bad as it sounds, and if I'm wrong feel free to let me have it, but: Why is it that you think you're so special that everyone else's noise is cogged belts, but for you it absolutely positively no way could be the cogged belts, to the point that you're spending an awful lot of time and money looking everywhere else?
Cheers (seriously),
Curtis
Whatever, but if you are paying $40 for a pair of matched Toyota alternator belts then you are not getting the 'Mud price from Cruiserdan.
-B-
Cheers (seriously),
Curtis
Curtis
I tired the WD 40 and didn't make much difference. I really didn't mean to come across as feeling "special". I never meant to imply it could absolutely not be the belts in fact I said that was my next task. What I did was a process of eleimination in finding out if the P/S was going out as it was leaking old fluid and low when I got it. So when I found a bad pulley I replaced it. Yes I listened to the Toyota guy but hey they swapped it for free. The only money I've spent is for the pulley and I don't think that is a lot. But this style of communication is tough and I'm not offended. I will be replacing the belts soon. I just had higher priorities at the time. It's all good
-B-
Got the quote from C-Dan
Welcome to MUD!!
Come by our little section of mud for Colorado Springs Folks
CO- Colorado Land Cruisers - IH8MUD™ Forums
Colorado Land Cruisers is the Club! hope to see you!
I'll get in touch when I can come up for air or from under the truck :)
If anyone is interested in my scarred spindle question check out the new thread.
Welcome to MUD :flipoff2:
Those cogged belts make a whining noise, trust me. BTDT. Sounds a bit like a spooling turbo. The replacement belts are about $12 each. If you are going to all the trouble of swapping idlers and not doing the belts (which you say are not in good condition) then I'm missing something here.
One other philosophical observation. If $40 prevents you from doing proper repairs and maintenance, you will not be a happy 80 series owner.
You also have me worried because you want to reuse hub seals. That's a false economy.
I kind of skimmed the posts, but did anyone else mention that the power steering pump on a 1996 80 series is not driven by a belt? It's gear driven like a heavy truck.
:flipoff2: Welcome
