INTI Rack Awning Mount
Brentbba
Former Golfer
OC, CA
Anyone mounted an awning to an INTI?
I've seen Ryan's mounts and found the following thread.
Show us your 80 Inti Rack Mods and Addons
The horizontal bars are just under 5" from bottom to top. Wonder if the 5" BajaRacks Metal Brackets for mounting an awning on their 5" tall rack would work. Sent a message via their site over a week ago and haven't seen a response.
What type of awning are you planning to purchase. If you are going to run a Foxwing style they are wider than the standard awning ....Rhino Rack has awning brackets that may work and you don't need 12 bolts to secure an awning ... 4-6 work fine. I have a Foxwing on one side and a Sun Seeker on the other secured with 4 bolts per awning. You could also have someone fab them ..,
Lou
I have a Yakima rack, with the lengthener in the middle. I have my ax, shovel and hi-lift on there, along with some back up lights. I drove thru a drive thru that was a C-hair too low and tore up my mounts and rain gutter, so we had to fab up some new stuff. Anyway, I want to also add an awning, do guys know of one that will mount easily without fabbing something? Thanks, and sorry if this is a hijack
ummm...yea, it's a full on hijack. What does your Yakima have to do with an INTI rack? o_O
Exactly, identical. We BOTH need awning mounts, and I bought mine before I even knew this one existed. I tried to rip the damn thing off at the ATM machine, but it was too stubborn to go. :flipoff2:
I have a fiamma awning mounted to my rack:
I basically notched the L bracket and mounted to the existing hardware on the gutter mounts. If I mounted it to the side rack as posted in the link provided, I wouldn't be able to reach it due to my J lift (I'm 5' 8").
It has been sturdier than expected as evidenced by the dent in the cover from wheeling and having the cruiser lean on the awning against a tree!
Salue - thx. I'm looking to mount mine up at the railing. I think putting a mount on the rack feet mounts would be pretty weak extending up as high as I need. I've got a side light down where you have your awning mounted and I need to go higher than where you have yours.
I like the side light idea. That might be really handy under the awning at night. Is it andLED type, or spot/flood type? Can you post a pic? Will be interested to see what you come up with.
It's an ancient PIAA Halogen. I've got one mounted on each side and two off the rear in addition to four up front behind the screen on the INTI.
As LED's continue to become more affordable for quality lights, I'll consider changing the old halogen's out for LED's. Less power consumption and brighter as well.
The Link from Rhino Rack has a bracket that fits the Yakima ...its for the Foxwing so you can drill holes to fit your awning
Some both already. He's also for a Flickr account or something like that with plenty of pics
Looking at his pictures those are not brackets attached to his rack...its just flat steel painted. With the plate on the inside of the rack once you tighten the bolts the awning and plate are pulled tight against rack.. Pretty simple setup and explains why he used so many bolts. If you go that route you might glue rubber strips on the awning which would protect your rack and make for better contact.
Thanks Luke111 - I've studied Unwired's pics both here and on his picture account thoroughly and do know what he's done.
