Thanks in advance for reading. I've found a lot of threads on intermittent power problems, but they don't sound quite like mine, I'm hoping someone can point me in the right direction to start. This issue has been going on very occasionally for couple years, but it's gotten more frequent recently.
First, my 94 is tired, it's got 285k on the clock and I use it offroad. I've had the truck for 12 years and 50k miles and have put all the hard miles on it. I did a lot of maintenance stuff (MAF, plugs, ignition, etc.) the first year I had it and it's essentially run great since.
Occasionally, especially when I first start, my truck has no power. It stutters and spits but won't go above about 10 mph. If I stand on the gas pedal the RPMs will slowly climb, but only if I really stand on it. I'll get up to about 3500 rpm and 25-30 miles per hour, stuck in first gear, and it feels like I'm pulling a 10,000 lbs trailer. Usually after a few seconds of holding WOT capped at 3500 rpm the truck will very suddenly perk up and start running and shifting normal. The suddenness of the change seems like an electrical issue to me.
When the truck is stuttering like this if I hold the throttle normal I can't even accelerate to normal traffic speed. I have to stand on the throttle and hope the RPMs climb. If I try to accelerate hard but not WOT (ie no kickdown), rpms can get up to 2500 ish but the transmission won't shift out of first and it doesn't kick into normal. It's like I'm pulling a trailer.
I have tried shifting into neutral when this happens with similar results, I have to stand on the throttle to get the RPMs to climb.
The engine occasionally throws a check engine light for smog systems. I have replaced all the smog parts and the light is mostly off these days, and it is currently off, so I don't think it's related to my power problems. There are no codes at all right now.
It seems to me like if it was fuel delivery (pump / filter / sock) then I wouldn't be able to get to high RPMs. TPS doesn't seem right since I can get high RPMs, just no power.
I'm trying to get ready to go back to the desert (PVD 2019!) and I'd like to iron out this gremlin first. I know it's a crap shoot with intermittent problems, what part do I change out first? Thanks!
-Dan
-Dan
