Interior lighting options beyond stock?
Just about everyone is dissatisfied with the interior lights in their trucks, or so it seems. I'm no exception, so I started toying with LED lights, seeing if I could get more output. I put two in the rear cargo light, just as a test, and they are brighter than the standard lights, but I don't think there is any more usable light, as it doesn't seem to light the cargo area up any more than the stock light.
Is there an option beyond LED's and the stock bulb? A brighter bulb, maybe? I just wish the inside of my truck lit up like my GF's moms RAV4, or her dad's new Taco....
hit up treeroot. he put leds in his stock housings that light up his driveway, the neighbors driveway, the apartments across the street, and attract moths and lifeforms from other planets.
you could always just mount up another light or two and wire them in. LED marker lights could work, depending on where you put them. or get one of those $15 harbor frieght 12v drop lights and mount it somewhere. PLENTY of light.
what are you doing in there that demands floodlights? I have the ARB lamp with a 15 ft cord to the cig lighter, useful for random rummaging in camping gear as well as under the hood or under the truck excursions. I hang it from the grab handles. I set my dome lights to be off when the doors open since they are bug magnets. (in Maine, we got bugs).
I think this is plenty just don't look directly at it without eye protection.
I have the 2 LED festoon bulbs. No brighter, just whiter...MUCH whiter. They're almost blue, but I toned 'em down with a little scotch tape and an orange magic marker. Warm white would probably look a bit better. They're fine, but not a brighter alternative to incandescents.
lol as for what I need all that light for... thats none of your business!! Nah, really, I mean the whole interior, not just the rear cargo area. The two LED's I put back there were just a test, and they are MUCH whiter, just not more light. I must be using the wrong LED's.
treeroot, what method did you use to install them? Would it be too much to ask for a pic of the inside of your overhead light setup? I just temporarily soldered two white (1000 mcd) LED's to a 220ohm resistor, and then soldered it to the contacts that the standard light uses to test effectiveness. I could just be using the wrong LED's too, so more info there would help.... Ill look into the other types of lamps as well, but I like the LED idea due to power usage.
There you go!
So what size is the cargo and back seat? (in mm's)
How can you tell which of those outputs the most light? The bulb info section is less than intuitive....
I emailed and asked.
The 48 SMT LEDs are smaller then the 25 SMT LEDs but net effect is brighter. That said the 25 SMT LED is brighter then the 36 standard LED.
So this is the end your looking for when getting the personal/maplight replacement right?
One more thing, how do you get the maplight out? Do you unscrew that screw below the sunroof controls and pull? Mine seems stuck. I don't want to bang on this thing like a neanderthal and break something if I don't need to. Suggestions?
Take out the one screw, and look very carefully. There is a small slot on one side (towards the windshield) that you use to pop it out.
Once you figure it out it's idiot simple....but still took me a while to figure it out the first time.
Yeah, earlier today i took the screw out and thought why doesn't this thing just fall down? WTF
I'll look for the slot next time I'm out there.
So is the Ba9 the correct end?
post #11 seriously - it's all in there.
I don't know what's going on with me. It is obviously in your posts and I looked at it but I guess I didn't look at everything. I'm just getting mixed up for some reason. Hopefully I have it now. Sorry for the frustration cause I would have been frustrated with me by now.:mad:
