ARCHIVE INTERIOR Cargo Carriers- FZJ80
Interested...I liked your original design better because I could use it with my AO drawers...now with this design that may no longer be possible.
- Mark
To me it doesn't look like there would be clearance for an AO drawer system under either version?
sorry for the confusion- they use the existing 3rd row brackets as a mounting point but don't require you to modify them so you can go back to using the 3rd row seats if you wish. Hope that's clear
I'm interested.
But still a tad confused.. does that mean the bolted down bar to the wheel well stays or do you have to unbolt that to install this? Basically is there a quick release to remove the water carrier and slap in the 3rd row seat, without using tools?
Also, curious if they would be sturdy enough to mount a spare tire (285/75) onto the side of them? With either straps or maybe a center screw design like Slee's interior tire mount?
Thanks for clarification :)
I actually like the look of the dimple plate on the CAD design but whichever way you go I want a set. If possible it would be nice to have enough surface area to mount the Quick Fist rubber clamps.
sorry for the confusion- they use the existing 3rd row brackets as a mounting point but don't require you to modify them...
But still a tad confused.. does that mean the bolted down bar to the wheel well stays ....
So, to be clear and prepared, the bracket for the 3rd row seating is needed?
Thanks.
here is a updated drawing
The flat part connects to the factory 3rd row seat brackets in the floor. The design will take up the least amount of space from the rear cargo area floor and between the fender wells.
That makes sense, cool!
Looks great! Please keep me in line for a set!
me too
I am definitely in. can you comment on how these would work with the engle fridge and slide(slees).
any comments on how close to being done?
The suspense is friggin killing me.......
i'm glad you guys are so excited! we are too. I've had a long time to live w/ the design- there are many improvements integrated into this.
We have come up with a lot of great refinements and Hanna has a great manufacturing plan-we will post progress and then, FINALLY! we can start pumping them out to you guys.
Also the entire cargo system is going to be awesome. Give us a couple weeks- the Hanna-man is in full-effect :grinpimp:
